Engineering How can a chip design engineer become a physicist?
A chip design engineer with three years of experience in ultra-low power audio and medical applications expresses a desire to transition into solving fundamental physics problems, feeling that current design challenges have become less stimulating. With a background in electrical engineering and a master's degree focused on integrated circuit design, the engineer seeks guidance on whether pursuing a master's or PhD in physics is necessary and how to strengthen their application. Responses emphasize the need for additional physics coursework, suggesting enrollment in upper-division physics classes at a local university to meet prerequisites for graduate programs. There is also a discussion about the relevance of pursuing a PhD in electrical engineering, with concerns that it may lead to similar work as current roles. Engaging with local university professors for advice on prerequisites is recommended, alongside considerations of the evolving nature of research opportunities in both physics and electrical engineering.
intrepid_atom
Dear physics lovers,
I've been working as a chip design engineer (designing SoCs for ultra-low power audio/medical applications) for the last 3 years at one of the top-5 semiconductor companies in the world. For the first couple of chip design cycles (~2.5 years) I was solving some really interesting design problems. Such problems now appear less challenging or interesting. After much deliberation I came to a conclusion that only by solving fundamental problems my thirst for problem-solving will be quenched. I loved physics as a high-school/college student (knew Halliday&Resnick backwards) and I still do. I would like to spend the rest of my life solving real-life physics problems.
I've an MS in Electrical Engineering with a focus in integrated circuit design. Given my background and where I want to go, what path should I take? Do I absolutely need a MS or a PhD in physics? If so, does my background hurt my chances of getting an admission? If I don't get a degree in Physics, then what are my options? Any helpful pointers or suggestions will be greatly appreciated.
Thanks a lot,
Dan
The short answer is yes, you need a credential in the field.
You don't really say what your background in physics is. Assuming that it is limited to the usual undergrad engineering sequence, you'll have to do a lot of remedial work before you could be admitted to an MS or Ph.D. program.
If you are serious about wanting to become a physicist, I'd suggest trying to find a local university where you could take a few upper division physics courses. Some schools have an "Open University" program where non-degree students can take a few courses paying per credit. After you've done most of the undergrad sequence, you could probably apply to an MS program, and if you did well there, a Ph.D. program.
Alternatively, if you are only interested in finding hard problems, you might want to consider a Ph.D. program in electrical engineering.
Seriously. Why switch to physics? In my opinion, EE (along with materials engineering, physical chemistry and more) has managed to snatch away or at least co-op many very interesting problems that might have traditionally been soley in physics.
There are useful, lively, new and exciting areas of research in physics. Unfortunately they are often forcably tacked onto the lumbering frankenstein that is modern physics departments. Sharing resources with a lot of that nonsense is worth avoiding, if you can do so easily.
TMFKAN64,
Thanks for the response. In terms of my actual physics background, you're right. My BS is also in EE, but I took classic mechanics, fluid mechanics, thermodynamics and elctrogmagnetics and engineering physics. In my MS I took 3 semiconductor device physics courses. Given that info, What all pre-requisites I need to take to make myself eligible for an MS-physics admit? Is it typically OK to contact professors of local universities to get a better idea of my prerequisites?
I considered PhD in EE, but I'm afraid I'll end up doing the same things I'm doing now after a gruelling ~5 years. I say that because I see PhDs in my own team who do more or less the same stuff I do. There are some niche areas where PhD in EE is a must-have. But, generally speaking PhD in EE is redundant especially when you are already in the industry. If I'm fresh out of school then doing a PhD in EE may make more sense. That's my understanding and it may not be 100% correct.
Thanks again for your ideas.
-Dan
intrepid_atom said:
In terms of my actual physics background, you're right. My BS is also in EE, but I took classic mechanics, fluid mechanics, thermodynamics and electromagnetics and engineering physics.
A quantum mechanics course would probably be nice to see, but it seems that you have the basics covered.
I think it's a good idea to get in touch with a local university and see what they have to say. (There is usually some obvious contact point for prospective students, so check their website.) The university where I got my MS (one of the CSU system schools) would admit students conditionally if they had a few undergrad prerequisites that they still needed to complete.
TMFKAN64,
Thanks for your valuable suggestions.
-Dan
10K
