C# Can anyone explain what this c# code does or give a C equalivent?
  • Thread starter Thread starter hadi amiri 4
    Code Explain
The discussion revolves around two C# functions, `Replace` and `Extract`, which manipulate individual bits within a byte. The `Replace` function sets or clears a specific bit based on the provided position and value, while the `Extract` function retrieves the value of a bit at a specified position. The C equivalent of the C# code involves changing the `byte` type to `char` and using pointers instead of references. Both functions utilize bitwise operators, which are consistent between C# and C. The primary application of these functions is in steganography, particularly for manipulating the least significant bits (LSB) in 24-bit BMP images. Understanding these functions requires familiarity with bitwise arithmetic, which is fundamental in programming for bit manipulation tasks.
hadi amiri 4
C# vs c !
Hello every body!
can anyone explain what this c# code does or give a C equalivent?
public static void Replace(ref byte b, int pos,
byte value)
b = (byte) (value == 1 ? b | (1 << pos)
: b & ~(1 << pos));
public static byte Extract(byte b, int pos) {
return (byte) ((b & (1 << pos)) >> pos);
Technology news on Phys.org
This looks like homework. What do you think it does?
The C code is essentially identical to the C# code given. Just replace the "byte" type with "char", and change the first parameter of Replace from a reference to a pointer.
If you want to understand this I suggest you google "bitwise operator". These are the |, &, ~ sort of operators and the C bitwise operators are the same in C#.
These two functions are used for empadding and extracting the bits from a byte ,they are used for steganography with LSB method in 24-bit .bmp pics,i just wanted to kmow that how they work ,i mean with some examples.can anyone help?:biggrin:
Well they're just simple functions to treat a byte like an array of bits and get or set single bit values out. So if you say Replace(ref x, 4, 1) you are setting the 5th most significant bit of the x variable with "1".
Extract(b,pos) in english says shift a 1 value up by pos, bitwise-and the result by b, then shift the value back down by pos (so that the only possible end results are 0 and 1). Replace(b,pos,value) says take the value referenced as b and if the value is 1 then bitwise-or the value by 1 shifted up by pos, otherwise bitwise-and with a mask which is the NOT of 1-shifted-up-by-pos. This is all pretty basic stuff so again I urge you to read up on bitwise arithmetic. Basically any introduction to the subject will cover the stuff happening in these functions.
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
Thread 'Project Documentation'
Trying to package up a small bank account manager project that I have been tempering on for a while. One that is certainly worth something to me. Although I have created methods to whip up quick documents with all fields and properties. I would like something better to reference in order to express the mechanical functions. It is unclear to me about any standardized format for code documentation that exists. I have tried object orientated diagrams with shapes to try and express the...
13K
