Experts Ask Your Questions Here
  • Thread starter Thread starter Todda468
Magnets can indeed wipe data from old, unshielded magnetic discs, but modern magnetic drives are shielded, and solid-state memory is less susceptible to magnetic interference. A sufficiently strong magnet, when held close for an extended period, can damage data on a hard drive, particularly affecting boot data and rendering the system unbootable. The debate around the effectiveness of magnets in damaging drives often hinges on the definition of "sufficient" strength and duration. Additionally, powerful magnets can destroy CRT monitors and may cause damage to computer systems through high-voltage transients generated by strong electromagnets, which can affect semiconductor components.
Todda468
I want answers from people who know what they are talking about.
Computer science news on Phys.org
There's no doubt that magnets would wipe old, unshielded magnetic discs. However, new modern magnetic drives are shielded and we have solid-state memory.
A sufficiently strong magnet, held sufficiently close, for a sufficiently long time can and will destroy data on a hard drive.
The conflicting true versus false claims you have heard are almost certainly based on an arbitrary definition of "sufficient".
On the other hand, I don't know if a magnet could do any damage to the computer system itself, except inasmuch as it could destroy the boot data stored on the hard drive, rendering the computer unbootable until a new system is installed.
Well they can definately destroy CRT monitors as well. I did it by semi-accident as a child once (my parents were not amused).
In order to destroy modern hard drives, magnetic field in the range of Tesla is required. Such a magnitude of magnetic field can be generated by powerful neodymium magnets, metallic scrap picking machine's electromagnet, MRI machine etc. Damage to entire computer can occur only by powerful electromagnet pulses which can create high voltage transients (of the order mega volts and mega amperes) sufficient enough to melt the p-n junction of the semi-conductors.
'struth.
I was considering the box/CPU only.
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
