Powering LM741 Op Amp Without -15V Supply
  • Thread starter Thread starter Blenton
    Opamp
Powering an LM741 op-amp typically requires a dual supply of ±15V, but alternatives exist for those without a negative voltage supply. Connecting a +30V to ground does not replicate the functionality of ±15V, as the latter provides a reference ground essential for op-amp operation. Creating a negative voltage can be achieved through methods like using a voltage divider or an inverting DC-DC converter, with the latter being a recommended learning project. PC power supplies can be utilized, but caution is advised due to potential minimum output current requirements and noise issues that may affect analog applications. Ultimately, a proper split power supply is necessary for circuits requiring stable negative voltage.
Blenton
I'm trying to build a circuit using a lm741 op amp, and normally the opamp requires +-15 V to run it. However currently I don't have a power supply that has a negative output.
Correct me if I'm wrong but isn't connecting the device from +15 and -15 the same as just connecting a +30 to ground supply?
If not how does one create a negative voltage short of buying a duel power supply? (I have a DC power supply that generates 5,7.5,9,12V)
The difference between +/-15V and 30V is the ground in the middle. You need low impedance supply rails with respect to your ground/reference voltage. Most of your opamp circuits with split supplies will use ground as a reference, despite there being no ground connection to the opamp IC itself.
You can try to artificially make a middle reference rail in a 30V system, but forming some sort of voltage divider to make 15V, and then bypassing the heck out of it with caps. Depending on your citcuit, that can work okay.
A better way for you (and a good learning project) would be to make an inverting DC-DC circuit, followed by a negative linear regulator (to eliminate ripple). Check out the inverting Simple Switcher series from National Semiconductor, for example. They are pretty simple circuits to design and build.
There is a good article on using opamps with a single supply here:
http://courses.cit.cornell.edu/bionb440/datasheets/SingleSupply.pdf
In Figure 2 they use an opamp as a buffer to give a stable virtual ground. Often two resistors and a bypass capacitor are all that is needed.
The article also has an excellent summary of filter circuitry.If your signals are at or near ground level, and cannot be coupled via capacitors, you would still need a real split power supply. This would happen if the signals were DC or slowly varying AC.
If you have access to the inside of your 12 volt power source and feel comfortable with modifying it safely, it might be possible to use a half wave voltage doubler to produce a negative voltage.
@vk6ro
Yes I've been reading the article, and it serves well to power op amps, however I also require negative volts to power a motor in reverse (the op amp to switch motor between forwards and reverse).
Do you think it would be possible/safe to use a powersupply from a PC for this?
PC power supplies can be used for general power supplies, but there are two issues to keep in mind.
First, some PC power supplies have minimum output current requirements. If you draw less than the minimum (from whichever rail is spec'd), that rail can go out of regulation, usually too high. Second, since they are switching power supplies designed for digital logic, they tend to have pretty noisy ripple. Not good for analog applications, although motors don't care about their ripple.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
