How to induce current on a static conducting material?
Inducing current in a static conducting material requires a change in magnetic flux, which can be achieved by moving magnets or the conductor itself. The discussion emphasizes that both magnets can be moved or the conductor can be rotated within a magnetic field to create the necessary flux change. Participants suggest using equations related to magnetic flux and angular frequency to calculate the induced voltage. Additionally, there is interest in creating a magnetic field with variable strength, although specific methods for this are not detailed. Understanding electromagnetic induction principles is crucial for effectively inducing current in the material.
Jay_zero
Dear Physicists,
I am currently thinking of a way of inducing a current in a conducting material by a magnetic field. I am not good at magnetism and electricity at all, but I think it should look like the picture below. By the way, the material in the middle does not move.
Does anyone think that this setup will help induce a current in the material? if not how should I do it. By the way, is it possible to change the strength of the magnets at all? Please guide me in the correct direction as I am very lost here and don't know where to look. Suggestions are much appreciated on what field to look at. Thank you everyone.
You need a change in magnetic flux to induce current . So you will have to move those magnets some how . What is your purpose for inducing current .
It is not used to power up anything electrical at all. However, I think it is silly to say that I don't even know if I really need a current in the material at all. Anyway, so I need to move the magnets? like left to right and back again? Do I have to move both magnets or one magnet? However, are there any equations to calculate how much magnetic strength I need for a given distance? And last question, how to create a magnetic field with variable strength?
Thanks again.
Watch the first 20 minutes of this video and he talks about electromagnetic induction and it might help you and it is a very good video.
Or you can move the conductor through the B field to induce current , Maybe you could have it rotating or something.
And if you have it rotating and you know the angular frequency, And you know the field strength , then you can calculate the magnetic flux as a function of time .
Using Flux=Acos(bt) where a is the cross-sectional area and b is the angular frequency
and the time derivative of this will be voltage .
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
