Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #11,581
And as for recent temperature data, I don't see anything interesting that correlates with the October 25th CAMS spike. The only thing I can spot at all from recent temperature data is a 0.8 degrees C rise in suppression chamber water temperatures between the 5am and 11am readings on October 28th.
http://www.tepco.co.jp/en/nu/fukushima-np/f1/images/11103012_temp_data_2u-e.pdf
I'll be looking at a much wider date range when I get the chance, but its anything like what I saw a month or 2 ago then any patterns likely won't be much more dramatic than the stuff I've just mentioned. Unless we think we can draw conclusions from dodgy CAMs data and some upward and downward trends in suppression chamber water temperatures, which I would like to be able to do but I doubt the data is strong enough to build interesting theories upon.
  • #11,582
I tried to work back from the activity. I came up with something in the region of tenths of a gram of Pu being enough to contaminate a 100 cubic metre volume with the detected quantity of Kr.
Could someone check if I'm in the right ballpark, at least? Cause if I am, we can't rule out spontaneous fission as a cause, I think.
Anyway, the conspicuous absence of Iodine is making my head hurt. It should be way more plentiful than Kr, no? Is it being kept in the water by chemistry, retained inside the (by now relatively cool) corium, or what?
EDIT: it's really late here, I'll ask a mod to delete if it turns out I'm delirious from lack of sleep.
LATER EDIT: wait, no. I forgot they flushed the piping with nitrogen prior to installing the stuff that enabled them to take these measurements in the first place.
http://www.4-traders.com/TOKYO-ELEC...clear-Power-Station-as-of-3-00-pm-O-13859684/
So yeah, who knows what the true concentration of Kr is.
  • #11,583
I've now looked at a much wider range of reactor 2 temperature & CAMS data. Aside from the things I already mentioned from late october, and a number of gradual increases in suppression chamber water temperature that I've gone on about before, nothing really leapt out at me. As far as I noticed the october 25th CAMS spike is the only time since the early days of the crisis that both a drywall and a suppression chamber CAMS data reading spiked in the same way at the same time. And the temperature reading described as 'RPV Supporting Skirt Upper Part' has fluctuated in a more noticeable fashion in recent days than it has tended to before, but we are still only talking about changes of less than 10 degrees C.
  • #11,584
zapperzero said:
This is the very first time that test results have been published. There is no timeline to follow.
They've only done one other gaseous sampling from the reactors, and also from R2, and the results from Aug 10 showed Xe-131m in much higher quantities. If these are the only noble gas test results, then its safe to say fission has been ongoing, yes?
What troubles me is that Tepco intends to only test for particulates for cold shutdown requirements. Wouldn't the US or France test for gases and tritium as well?
  • #11,585
I have a question. How about sticking a bit of metal wire inside to measure neutron flux via activation? It's probably easier than a full-on borescope expedition? There must be instrumentation pipes that can be used, at least to reach the inside of the PCV. In fact, I think I remember reading somewhere that such "sensors" are part of the standard equipment.
  • #11,586
Latest update from NHK says TEPCO retracts claim of criticality, states that the Xenon level is consistent with spontaneous fissioning of curium-242 and -244.
  • #11,587
Did they ever claim that there was a criticality or they just said that they couldn't discard the possibility? I know we already have the tendency to eliminate all the qualifiers from the Japanese reports, but it seems in this case both Tepco and NISA meant it when they said that "the possibility couldn't be excluded." The hypothesis of spontaneous fission being the cause was also mentioned from the beginning.
  • #11,588
NHK themselves said "retracts", but that might have been media overreaction. I think a few of the networks were pretty content to make the criticality assumption, and I know a number of netizens around the world were patting themselves pretty hard on the back yesterday.
  • #11,589
http://www.yomiuri.co.jp/science/news/20111103-OYT1T00346.htm (3 November 01:12 PM) Tepco said that Xenon can be explained by spontaneous fission of curium. It was found in a more detailed analysis that in the case of a small scale criticality, ten thousand more Xenon would be detected. The fact that xenon was still found after the boron injection also provides ground for believing that criticality is not occurring.
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_111103_01-e.pdf "Schematic diagram of the nuclear fission reaction"
http://jp.wsj.com/Japan/Companies/node_336401 (3 November 05:09 PM) A a ten thousand higher value resulted of a calculated estimation of Xe-135 concentration "based on the output energy in case of criticality". Also, a calculation of xenon concentration in case of spontaneous curium fission almost matched the present measured values.
  • #11,591
Attached is my rough sketch to estimate the amount of Xe-135 to be expected as a consequence of spontaneous fission in Pu-240, Cm-242 & Cm-244. I made it really quickly and have not been able to double-check my figures, so if you see errors, please point them out.
Some conclusions:
  • The main SF contributor indeed seems to be Cm-244.
  • However, the majority of fissions occurs in U-235 due to subcritical multiplication - at a rate highly dependent on the assumed multiplication factor.
  • Thus boron should have an effet on the Xe-135 concentration even though it would be due to subcritical multiplication.
  • The main uncertainty lies in the release fraction of Xe-135 from the fuel/corium. The measurement data given by TEPCO conincides with release fractions between 0,001 .. 0,01 % in my sketch - a plausible figure assuming the fuel (in whatever state it is) is cool.
  • Effect of nitrogen injection in the containment was neglected in my sketch - however, its effect is smaller than one decade, and thus smaller than the uncertainty in the Xe-135 release fraction.
All in all, it appears that the measured Xe-135 concentration would be well in line with the figures to be expected due to spontaneous fission, and no criticality is needed to explain them.
  • #11,592
Some conclusions:
Your work is spot on. I just logged into post my results and you stole my thunder. So I will simply say congratulations and independently confirm your results. Only minor difference is that I believe Pu-238 is actually a larger source than Pu-240, but two orders of magnitude less than the Cm isotopes. Good job!
  • #11,593
Questions have been asked by several posters about why radioiodine has not been measured in the gas samples. This may mean that the pH of the water in the containment and vessel have remained alkaline and is keeping the iodine in solution until it decays. Acidic pH allows radioiodine to release as iodine gas. Thus only the iodine generated by beta decay in of Xenon in the containment atmosphere would be available in samples. Calculating the equilibrium iodine concentrations from that source will provide an answer if it is less than the detection threshold.
  • #11,594
Todays status update has info about a further rise in hydrogen density, and measures taken.
Unit 2
11/3 12:40 In order to improve reliability of nitrogen injection, additional flow gauge is started to install at the Unit 2 nitrogen injection line.
Around 14:00 The work was finished. Although nitrogen injection was stopped for approx. 10 minutes during the work, there were no significant changes in the parameters
11/3 16:50 Since some increase at the hydrogen density (hydrogen density of 2.9% [As of 16:30 on 11/3]) in the exhaust gas from PCV was observed from the last time of nitrogen injection amount change (hydrogen density of 2.7% [As of 18:10 on 10/30]), nitrogen injection amount was changed from 21m3/h to 26m3/h.
Taken from http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_111103_02-e.pdf
  • #11,595
Thank you, NUCENG. That makes sense.
My other question was whether the krypton and xenon could possibly account for the occasional synchronized transient spikes seen around Kanto. The spikes are pretty small, around 0.05 uSv/h above steady-state levels, but the krypton and xenon concentrations measured here look so darn low (barely above detectable limits even when sniffing gas directly from inside the reactor) that it seems hard to believe they could be responsible for measurable signals a couple hundred kilometers away. Unless somehow even very low levels of these isotopes can trick detectors calibrated for cesium into reporting much higher values somehow? (I.e., if this gas were wafted past a GM counter, what kind of reading would that counter report?)
Otherwise, maybe the radon-daughters-kicked-up-from-the-soil-by-rain theory is the correct one?
  • #11,596
Unit 2
I don't remember if the following 30 October pdf was already mentioned in this forum :
Regarding the hydrogen concentration in the gas emission of the gas management system of the reactor containment vessel in Unit 2, we confirmed that it increased to approx. 2.3vol% at 5:00pm on 29 October, which was approx. 1vol% at the beginning of the operation. Therefore we adjusted the amount of injecting nitrogen gas from approx.14 m3/h to 16.5 m3/h in order to avoid exceeding the combustible threshold concentration (4vol%).
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_111030_01-e.pdf
http://www.asahi.com/national/update/1030/TKY201110300269.html (30 October) 1% is the hydrogen concentration measured at the start of the gas extracting system on 28 October. A Tepco official, Susumu Kawamata, said "Didn't hydrogen get out because an air flow occurred ?".
  • #11,597
http://www.asahi.com/national/update/1030/TKY201110300269.html (30 October) says that 1% is the value on 28 October. It quotes a Tepco official, Susumu Kawamata, giving some kind of explanation but I don't really understand : "Didn't hydrogen leak out because an air flow occurred ?".
It is unlikely that temperatures are causing any further zirconium water reactions. Radiolysis and corrosion processes will generate Hydrogen. Lots of carbon steel is exposed to warm wet conditions. As corrosion layer builds up rate should gradually decrease. May need to control pH to stabilize the corrosion layer.
  • #11,598
Can you give me a reference? I am a little confused if they are reporting a dose rate in place of activity for a specific isotope.
  • #11,599
I'd like to ask this question again. If no answer that's OK, but I am very concerned about the fact that Tepco has not been made to do more sampling of gaseous emissions. The only other gas sampling done, on Aug 9, they found Xe-131m at 3.8 X 10¹ to 4.7 X 10¹ Bq/cm3 in the lower floors of Unit 2. At that time little significance was placed on these readings. However, they now have readings of Xe-131m at 10-⁴, and concerns are raised.
I am confused. Were the Aug findings significant. And if so, with there only being two tests for gaseous emissions that would indicate fission occurring, would this not imply ongoing fission and criticality, and not spontaneous fission, especially as it appears the ongoing fission is winding down.
Wouldn't these findings necessitate/force further testing per regulations.
And lastly, what would be the requirements of a plant in America experiencing similar conditions.
And again, if these questions don't need answering, I apologize.
  • #11,600
Is it really so? In my reference inventory, the alpha activity of Pu-238 is about 5 times larger than that of Pu-240, but its SF probability is so much lower (1,8e-9 vs. 5,5e-8) that the SF rate would actually seem to end up lower by a factor of 5 (9e6 vs. 5e7):
[nuclide] [Bq] [T12] [T12(s)] [SF T12] [SF t12(s)] [SF prob.] [nu] [SF rate] [SF neutron production]
Pu-238 5,00E+15 87,7a 2765707200 4,90E+10 1,55E+18 1,79E-09 2,2 8,95E+06 1,97E+07
Pu-240 9,00E+14 6550a 2,06561E+11 1,20E+11 3,78E+18 5,46E-08 2,2 4,91E+07 1,08E+08
Cm-242 3,00E+16 162,8d 14065920 7,20E+06 2,27E+14 6,19E-08 3 1,86E+09 5,58E+09
Cm-244 4,00E+15 18,11a 571116960 1,40E+07 4,42E+14 1,29E-06 2,8 5,17E+09 1,45E+10
Even though the conclusion is the same, it would be nice to know where and why our results differ in this respect.
  • #11,601
http://www.meti.go.jp/press/2011/11/20111104007/20111104007-2.pdf Report from Tepco to NISA about the xenon detection. (4 November 2011, Japanese, 18 pages)
  • #11,602
  • #11,603
thebluestligh said:
Thanks Tsutsuji as always, I found a report from TEPCO in English version as well
http://www.tepco.co.jp/en/press/corp-com/release/betu11_e/images/111104e19.pdf
If I understood the TEPCO report correctly, they have
(a) completely neglected the subcritical multiplication, justifying this by conservativity
(b) assumed all Xe-135 created by SF is immediately released in the containment airspace, which I think is a huge error in the non-conservative direction, since the cool fuel/corium should certainly be able to contain a significant amount of the fission products
Did I miss something? Can someone make better sense of the report?
  • #11,604
I'm more interested in why they keep harping on about Curium. It's certainly not the only fissile in there.
To your first question: it is strange indeed.
As to your second question, they are probably assuming that the corium is saturated, so naturally all excess production goes into the containment immediately.
  • #11,605
Thanks for the English version.
The following translation, while not wrong, was forgetting to mention that the ratio is found using the krypton 85 measurements:
Collection efficiency of the charcoal filter is 1566 times as determined from the ratio of the values of Kr-85 measured in the charcoal (5.3E-1 Bq/cc) and [STRIKE]the value measured[/STRIKE] in a vial (8.3E2 Bq/cc).
  • #11,606
The following is from
If the Unit 2 fuel is in the critical state, Xe135 concentration is observed 4 orders of magnitude larger than current level. Therefore, present state is not considered critical.
OK, so on Aug 9 they found Xe-131m at 3.8 X 10¹ to 4.7 X 10¹ Bq/cm3 in the lower floors of Unit 2. This is 5 orders of magnitude greater. According to Tepco's analysis criticality has occurred. Am I missing something?
  • #11,607
The contribution of the residual I-131 (remaining in the containment water since March) on the Xe-131m production.
  • #11,608
Via http://ex-skf.blogspot.com/2011/11/xenon-detection-in-reactor-2-different.html" :
Comparison between the three gas tests on October 28th, November 1st and November 2nd. Looks quite funny. With the detection limits being very funny.
So... what the heck? No wonder they didn't detect any Xenon on October 28th.
  • #11,609
Thanks rmattila. Woudlnt the residual I-131 be gone by then. And certainly not in numbers to produce those levels of Xe-131m.
  • #11,610
I am using a different source term list from a US BWR4 and the fission branch percentage and isotopic yields I used from an old textbook. The textbook data includes data uncertainty ranges which I used to produce conservative (low) results. I used the same source term and updated values for fission branch and yield from http://atom.kaeri.re.kr/index.html and now Pu-240 is about 4 times larger than Pu-238. Since the data I got online has no uncertainty data I classify the new results as a best estimate case.
My analysis included 4 Uranium isotopes, 1 neptunium isotope, 6 Plutonium isotpes, 3 americium isotopes, and 5 curium isotopes that can spontaneous fission. All of my results are well within one order of magnitude of yours which is what I believe is reasonable agreement based on different data and the uncertainty of that data. Switching to the new values did not change that result, because the effects of curium seem to control the data.
Other than that I made several assumptions and some additional data:
  • I developed and solved a linear first order differential equation based on fission and spontaneous fission sources and removal by decay and leakage. It demonstrated that the isotopes of concern are appropriately treated as equilibrium values due to the long half lives of the fission sources.
  • I assumed that the relative sources for spontaneous fission
  • My inventory lists 50 transuranic and actinide isotopes and is based on a typical equilibrium core. Japanese operating cycles are probably shorter and so transuranic sources may be overestimated.
  • I assumed a single fission product yield curve for U-235.
  • I assumed a single value for neutron yield from fission.
  • I assumed zero out-eakage, but ran cases for 5, 10, and 20% keakage rates.
  • I included cases for Keff and subcritical multiplication from 0.7 t0 0.999. I used the results for Keff -0.8 for consistency.
  • I included release of Xe from I Beta decay.
  • I used a smaller free volume for containment to account for a water level inside containment.
  • I uswd source terms based on 8 months decay and buildup.
49K
  • · Replies 41 ·
  • · Replies 2K ·
60
463K
20K
  • · Replies 763 ·
280K
  • · Replies 38 ·
16K
12K
