Ground Anchor - Lateral and Uplift Resistances
  • Thread starter Thread starter HauntedMines
    Ground
To approximate the anchoring strength of a partially buried concrete caisson for a guy wire, consider the mass of the caisson, soil type, and its shape and size. Practical rule-of-thumb calculations can provide guidance without needing precise figures. Resources such as standard engineering handbooks and civil engineering literature can offer established methods and insights. It's important to ensure the design prevents the caisson from being dragged or uprooted. Utilizing existing knowledge in civil and foundation engineering will aid in achieving effective anchoring.
HauntedMines
Howdy -
I'm looking for a way to approximate the anchoring strength of a partially buried concrete caisson (pier). It would be used for anchoring a guy wire coming into it at about 45-degrees from above. Most of it's in the ground, a few inches sticks above where the cable fastens to it. The design goal is to not have it dragged thru the ground like a plow, or plucked up from the earth! :-)
I'm not after super-precise calculations, but practical rule-of-thumb things to help me design the anchor/pier. I'm fairly certain these things matter:
* Mass of the concrete caisson
* Soil type (sandy w/some clay, packs well)
* Shape & size of the caisson
I'm not sure how to get started,
Thanx,
- Steve
I think you can find something on this if you do some digging in standard engineering handbooks, etc. This sort of information is definitely known, and there is no point in re-inventing the wheel (or anchor). Check civil and foundation engineering sources for starters.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
