Fractional power equation. Solution domain.
The discussion focuses on solving the equation \sqrt{x^2-y^2}+\sqrt{\epsilon x^2-y^2} = \beta for x, given constraints y>0, \epsilon>1, and \beta in the complex numbers. It is noted that squaring the equation leads to four potential solutions, but numerical tests indicate valid solutions only for larger values of |\beta|. When specific values of y, \epsilon, and \beta are set, the results can become nonsensical, particularly when \epsilon deviates significantly from 1. Participants emphasize the need for a quantitative analysis of the solution domain, suggesting that constraints on \epsilon and \beta will affect the valid ranges for x and y. The conversation concludes with a recommendation to analyze the solution space by examining the bounds of the parameters involved.
Final ansatz
Hi everyone,
I'm currently looking to solve an equation of the general form: \sqrt{x^2-y^2}+\sqrt{\epsilon x^2-y^2} = \beta. I'm interested in solving this equation for x assuming y>0, \epsilon>1 and \beta \in \mathbb{C}. By squaring the equation twice I can find four potential solutions of the form:
x = (-1)^n \sqrt{ \frac{\beta^2}{(1-\epsilon)^2}\Big[1+\epsilon+(-1)^m \frac{2}{\beta}\sqrt{\epsilon y^2(2-\epsilon)+\epsilon\beta^2-y^2}\Big]} \ \ \ \ \ \ \ \mathrm{for}\ \{n,m\}\in \{1,2\}.
Now, I have tested these solutions numerically for parameters roughly in the range y\in ]1.67, 2[ and with \epsilon \in ]1.01, 4[. Generally, I seem to be getting proper solutions if |\beta| is "large" - but if I set e.g. y = 1.9, \epsilon = 2 and \beta = 0.02 + i 0.01 then the solutions are wrong.
I'm consequently quite convinced that \sqrt{x^2-y^2}+\sqrt{\epsilon x^2-y^2} = \beta only has solutions for certain parameters choices - what I want to find out is; can I analytically express when the equation has a solution? I.e. when is the solution domain of the equation empty?
I'll look forward to reading your replies!
Mathematics news on Phys.org
Hey Final ansantz and welcome to the forums.
For your question I'm going to assume that |B| is approximately zero. This implies:
√(x^2 - y^2) + √(ex^2 - y^2) = β ~ 0 which implies:
√(x^2 - y^2) ~ -√(ex^2 - y^2) which implies
x^2 - y^2 ~ ex^2 - y^2 which implies
x^2 - ex^2 ~ 0 which implies
x^2[1 - e] ~ 0 which implies x^2 = 0 or e = 1 for this approximation.
But if this relation holds (or is a good approximation which will be the case for |B| being really small), then if e is significantly different from 1, then you will have a problem and get 'non-sensical' results.
If you wanted to do a better analysis of saying 'what' values should be used to get a solution, then instead of making B = 0, you would introduce some kind of epsilon term that corresponds to information about the norm of B.
But yeah given the above, if your e value is near two, then I can see where your answers would give radically different answers that don't make much sense.
Thanks for your reply and your kind welcome chiro.
I agree that your suggestion is a good way to qualitatively understand the origin of the problems - and it's clear that the issue becomes significantly more complicated when \epsilon \neq 1.
I would however still be very interested in any quantitative, analytical statements about the solution domain of the problem.
In terms of analyzing the problem, you need to take into account your constraints and the effects they have on the solutions.
What will happen is that because you have constraints on your \epsilon and \beta this means you will have constraints on y and subsequently x as well.
If the solutions go outside of these constraints then you will get answers that make no sense since basically these answers assume values that lie outside of your constraint which means that you from an equality to a non-equality (I won't say inequality because that's not what it is: it's a non-equality).
Probably the best way I think you should go about this is to analyze what the solution space is for the lower and upper bounds of your \beta and \epsilon intervals and then using these results get all of the intervals for x and y.
So for example with epilson, first set it to zero and get properties of the rest, set it to infinity, get the properties for the rest then do the same for beta and take the intersection of all the results for x and y and that will tell you what y should be and as a result what x should also be since x is just in terms of y.
http://www.datasea.info/avatar1.jpgThanks for your reply and your kind welcome chiro.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
