SU(2) axial and vector subgroups
  • Context: Graduate
  • Thread starter Thread starter LAHLH
    Axial Su(2) Vector
The discussion revolves around the decomposition of the group SU(2) into its axial and vector subgroups, particularly in the context of the U(2)_L x U(2)_R global flavor symmetry of the chiral Lagrangian. Participants explore the implications of this decomposition, the nature of the generators involved, and the relationship between these symmetries and physical phenomena such as pion masses and chiral symmetry breaking.
  • Some participants explain that the group SU(2)_L x SU(2)_R has 6 generators, which can be combined to form vector and axial symmetries through addition and subtraction of the generators.
  • Others argue that the axial generators correspond to the broken symmetries in QCD, leading to the emergence of three pions.
  • A participant questions the relationship between the definitions of vectors and pseudovectors in this context.
  • Another participant elaborates on the axial transformation law involving the Dirac components of fermion fields and the role of \gamma_{5} in defining axial transformations.
  • Some contributions draw analogies between chiral components of fermions and circularly polarized photons to explain the nature of vectorial and axial transformations.
  • A later reply cites a reference from Weinberg regarding the implications of unbroken chiral symmetry and its relation to nucleon mass.
  • Another participant raises a question about the conservation of SU(2)_V and the spontaneous breaking of SU(2)_A, seeking clarification on how vector and axial charges act on hadrons.
Participants express differing views on the nature of the decomposition of SU(2) and the implications of axial and vector symmetries. There is no consensus on the relationship between these symmetries and hadron physics, as some questions remain unresolved.
Some discussions involve complex mathematical expressions and transformations that may depend on specific assumptions or definitions, which are not fully resolved in the thread.
LAHLH
Hi,
Could someone explain to me how to split SU(2) into its axial and vector subgroups, what does this mean?
(The context I'm trying to understand this in is the U(2)_L x U(2)_R global flavour sym of chiral Lagrangian)
A related question: I know that the three axial generators of SU(2)_L x SU(2)_R get broken, and this leads to the three (pesudo)-goldstone bosons; the three pions. But why are there three axial generators of this group?
thanks
The group SU(2)_L x SU(2)_R has 6 generators T^a_L, T^a_R (a=1,2,3).
We can also use generators T^a_L + T^a_R and T^a_L - T^a_R. The first one generates SU(2)_V and the second one generates SU(2)_A. So you can think of vector and axial symmetries as a change of basis of SU(2)^2.
The axial generators are the broken ones in QCD, giving rise to the 3 pions.
Note that your question as phrased: "how to split SU(2) into its axial and vector subgroups?" makes no sense, as a SINGLE SU(2) doesn't have such a decomposition.
Hi Blechman,
Could you tell me why with addition of these generators the group is "vectorial" and "axial" with subtraction ?
Thanks
"Vector" means L and R fermions transform the same way:
\psi_L\longrightarrow e^{i\alpha^aT_L^a}\psi_L,\qquad\psi_<br /> R\longrightarrow e^{i\alpha^aT_R^a}\psi_R
Hence + sign.
"Axial" means L and R fermions transform oppositely:
\psi_L\longrightarrow e^{i\alpha^aT_L^a}\psi_L,\qquad\psi_<br /> R\longrightarrow e^{-i\alpha^aT_R^a}\psi_RHence - sign.
thanks
I accept your answer but what is the relationship with the usual definition of vectors and pseudovectors.
I'm sorry if this is obvious.
The word “Axial” indicates the presence of \gamma_{5} in the transformation law.
Consider the following axial transformation of a fermion field with TWO FLAVOURS;
\Psi \rightarrow U_{5}\Psi \equiv \exp (i \frac{\epsilon . \tau}{2}\gamma_{5}) \Psi . \ \ (1)
In this, \gamma_{5} operates on the Dirac components of \Psi, while Pauli’s matrices \tau^{i} operate on the internal 2-dimensional flavour space of the fermions. We may call this group SU(2)_{5}. This transformation takes on a simple form when expressed in terms of the chiral components of \Psi. That is
<br /> \Psi_{R}\rightarrow V \Psi_{R} \equiv \exp( i \frac{\epsilon . \tau}{2}) \Psi_{R},<br />
<br /> \Psi_{L}\rightarrow V^{\dagger}\Psi_{L} \equiv \exp( - i \frac{\epsilon . \tau}{2}) \Psi_{L}.<br />
This can be shown by expanding eq(1) in a power series, and using the following
\Psi = \Psi_{R} + \Psi_{L},
\gamma_{5}\Psi = \Psi_{R} - \Psi_{L}.
So, the 8 \times 8 transformation matrix U_{5} can be written as
U_{5} = VP^{+} + V^{\dagger}P^{-}\ \ \ (2),
where
P^{\pm} = \frac{1}{2}(1 \pm \gamma_{5}),
are projection operators.
From eq(2), it follows that
\gamma^{\mu}U_{5}= U^{\dagger}_{5}\gamma^{\mu}.
This means that \Psi and \bar{\Psi} transform in the same way,
\Psi \rightarrow U_{5}\Psi,
\bar{\Psi}\rightarrow \bar{\Psi}U_{5}.
Thus, chirally invariant Lagrangian must be constructed out of massless fermions; the presence of a small fermion mass term provides a mechanism for breaking chiral symmetry.
Since our fermion field has two flavours, the theory must also be invariant under the global group SU(2). So, the total symmetry group is SU(2) \times SU(2)_{5}. This group is equivalent to SU(2)_{L}\times SU(2)_{R} with element
<br /> U_{L}U_{R}= \exp(i\frac{\epsilon_{L}.\tau}{2}P^{-}) \exp( i \frac{\epsilon_{R}.\tau}{2}P^{+}),<br />
where \epsilon_{L} and \epsilon_{R} are the independent parameters. To see the equivalence, let \Psi_{L}= P^{-}\Psi, and \Psi_{R}= P^{+}\Psi be associated with the (finite dimensional) irreducible representations of Lorentz group (1/2,0) \oplus (1/2,0) and (0,1/2) \oplus (0,1/2), respectively. The transformations under two commuting SU(2) groups are
(2,1) \in SU(2)_{L}:
\Psi_{L}\rightarrow U_{L}\Psi_{L}\equiv \exp( i\frac{\epsilon_{L}.\tau}{2})\Psi_{L},
\Psi_{R}\rightarrow \Psi_{R},
which can be combined into
<br /> \Psi \rightarrow e^{i\frac{\epsilon_{L}.\tau}{2}} \frac{1}{2}(1 - \gamma_{5})\Psi + \frac{1}{2}(1 + \gamma_{5})\Psi,<br />
or
\Psi \rightarrow \exp(i\frac{\epsilon_{L}.\tau}{2}P_{-})\Psi .
(1,2) \in SU(2)_{R}:
\Psi_{L}\rightarrow \Psi_{L},
\Psi_{R}\rightarrow U_{R}\Psi_{R} = \exp( i\frac{\epsilon_{R}.\tau}{2})\Psi_{R},
which we can write as
\Psi \rightarrow \exp(i\frac{\epsilon_{R}.\tau}{2}P^{+})\Psi
Therefore, the combined SU(2)_{L}\times SU(2)_{R} transformation is given by
<br /> \Psi \rightarrow U_{L}U_{R}\Psi = \exp[i(\epsilon_{L}P^{-} + \epsilon_{R}P^{+}) . \frac{\tau}{2}] \Psi . \ \ \ (3)<br />
If we define
\alpha = \frac{1}{2}(\epsilon_{R} + \epsilon_{L}),
\epsilon = \frac{1}{2}(\epsilon_{R} - \epsilon_{L}),
then, the SU(2)_{L}\times SU(2)_{R} element U_{L}U_{R} becomes
<br /> U_{L}U_{R} = \exp(i\frac{\alpha . \tau}{2}) \exp(i\frac{\epsilon . \tau}{2}\gamma_{5}),<br />
which belongs to the original symmetry group SU(2) \times SU(2)_{5}.
The meaning of chiral symmetry is, according to eq(3), the statement that an SU(2) symmetry can be INDEPENDENTLY realized on the two subspaces projected out by the P^{\pm} operators, i.e., the transformations on these two spaces can have different parameters.
Regards
Sam
Thanks
In the essence it's simple: The two chiral components \psi_L and \psi_R
have some similarities with left and right circular polarized photons.
Independently they propagate at the speed of light, however if you
couple them together then the combined momentum is the sum of
the two individual momenta and the resulting propagation speed of
the particle can be anywhere between +c and -c.
For the combined momentum one first calculates the individual momenta.
\psi_L\tilde{\sigma}^\mu\psi_L and \psi_R\sigma^\mu\psi_R
The sum of these two is the combined momentum, a vector.
However \psi_L\tilde{\sigma}^\mu\psi_L is also a measure for left handedness while
\psi_R\sigma^\mu\psi_R is a measure for right handedness.
This means that when you subtract the two you get their combined
"handedness", which is an axial vector.Regards, Hans
Thank you very much for your answers.
It just remains for me to make a synthesis of these aspects!
Citation from Weinberg´s second Volume on Quantum Field Theory Page 184 (botton of the page):
"It is not true that an unbroken chiral
symmetry necessarily implies a zero nucleon mass, unless we make further assumptions
about the matrix elements of the axial-vector current ."
A good and lucid treatment on chiral spontaneous symmetry breaking can be found in my opinion in Chapter 9 of "Stefan Pokorski-Gauge Field Theories".
I have another question that maybe fits here:
In a hadron physics lecture some ratios of hadron masses where given to proof that SU(2)_V is conserved, while SU(2)_A is spontaneously broken, e.g.
SU(2)_V \hspace{20mm} \frac{m_{\pi^+} - m_{\pi^-}}{m_{\pi^+} + m_{\pi^-}} = 0.1\%
SU(3)_V \hspace{20mm} \frac{m_{f_0} - m_{\pi}}{m_{f_0} + m_{\pi}} = 56\%
While the first one kind of makes sense to me the second does not.
How does the vector and axial charge act on hadrons?
Thanks!
  • · Replies 27 ·
