Non return valve location - booster pump/accumaltor
  • Thread starter Thread starter bellshom
    Valve
In a pipe system, a booster pump increases water pressure, and an accumulator is positioned after the pump. A non-return valve is necessary at the pump outlet to prevent backflow into the pump. The correct placement for the non-return valve is between the pump and the accumulator. Additionally, a manual dump or drain valve should be installed between the non-return valve and the accumulator for maintenance purposes. Proper configuration ensures system efficiency and safety during repairs.
bellshom
Hey,
Just something i wanted to confirm, in a pipe system a booster pump is used to boost the water pressure. A accumaltor is postioned after the pump, a non return valve is required at the pump outlet. I believe the non return valve should be before the accumaltor but after the pump.
Is this correct.
Cheers
Yup. To prevent the Accumulator from backflowing through the pump. Also note (I don't know what you may be using this for) you'll want a manual dump/drain/sample valve between the check (non-return) valve and the accumulator to relieve the system of energy for maintenance or repair of the circuit.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
