Massive Stars Spin Faster: The Reason Explained
Massive stars spin faster than less massive stars primarily due to their formation from larger molecular clouds, which possess more angular momentum that is conserved during star formation. While various processes can reduce a star's angular momentum, the key question shifts to why low-mass stars spin slower. One hypothesis suggests that low-mass stars experience strong magnetic coupling with surrounding gas, leading to angular momentum loss. Additionally, high-mass stars may form in close binaries, allowing them to convert orbital angular momentum into spin. Ongoing research continues to explore these mechanisms and the dynamics of stellar rotation.
Sean Pan
It is said that massive stars spin faster than less massive ones and I am always wondering why.Could someone please tell me the reason? Thanks a lot.
Astronomy news on Phys.org
Hi Sean Pan, welcome to PhysicsForums. The basic idea is that more massive stars formed from larger molecular clouds. Larger molecular clouds had more angular-momentum, and that angular-momentum is (largely) conserved in the star-formation process. Thus you end up with a faster spinning star.
Thanks, but there are many processes in the forming of stars that can reduce the angular momentun of the centural stars. Maybe I should have paid more attention to its initial angular momentum, but other factors should also be considered. Since star forming last a very long time, I think the final state may not depend largely on its original states.
We would expect all stars to spin rapidly, because we believe there is always ample angular momentum in the molecular cloud. So the question is not so much why do massive stars spin faster, it is why do low-mass stars spin slower. This is an ongoing research question, but one idea is that they tend to have a strong magnetic coupling with the gas that is forming them, and this coupling involves magnetic field lines that connect the rotating star to gas that is very far away from the star, which is in orbit. Kepler's laws say that the farther away gas is, the longer is its orbital period, so you have a rotating star with a short rotation period connected to gas with a long orbital period, and this tends to rob the star of angular momentum (and send it out to that gas way out there). Then you need a mechanism to get much of the high-angular-momentum gas to escape the system, and you can "spin down" your star (since this can happen with an accretion disk, it is also called "disk locking"). I'm not sure what the present status is of understanding how reliable this mechanism is, but no doubt many questions remain unanswered. For one thing, we might imagine that high-mass stars could also lose angular momentum in similar ways, so then we'd be back to asking why they spin so fast. It is thought that high-mass stars are even more likely to form in close binaries, which can then merge and convert the orbital angular momentum of the merging stars into spin. But that can happen to low-mass stars too, so then we are back to asking why low-mass stars spin so slowly! If you look at young low-mass stars, you find the younger they are, the faster they spin, so they are losing rotational angular momentum long after than have formed. Here interactions between magnetic fields and the winds from the stars are thought to play a key role, but you then have to explain why the winds are so strong in young stars. So you see, there is plenty of grist for the research mill here!
Regardless of the mechanism for shedding angular momentum, I would guess that one of the basic reasons is that more massive stars simply have much more momentum to shed to slow down to a given rotation rate.
Thanks a lot for your very detailed analysis!
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
