Obtaining Electricity from the Earth's Magnetic Field
Building a copper ring to orbit Earth for electricity generation from the magnetic field is impractical. While a stationary ring could initially induce a current due to Earth's rotation, it would eventually rotate with the Earth, leading to no change in magnetic flux and thus no induced EMF. A conductor in a polar orbit could induce some charge, unlike one in an equatorial orbit. NASA's past experiments with the Space Shuttle showed that the slow orbital movement generated minimal charge, even with a long conductor. Ultimately, the challenges of maintaining a functional system make this concept unfeasible.
AliAhmed
If we would build a copper ring that would orbit around the Earth (like a big belt), could we generate electricity from it (because of the Earth's magnetic field). I know it's impractical, but I'm curious as to how much electricity we could get.
No, I don't think this would work. Yes, the rotating Earth would induce a current in a stationary ring, but the interaction between the current and Earth's field would produce a torque on the ring causing it to rotate in the same direction as Earth's rotation. Eventually the ring would simply rotate along with the Earth, and there would no longer be a change in magnetic flux through the ring. No flux change, no induced EMF or current.
Thanks for that. Though it's a little disappointing, it's nice to here why it won't work.
A charge is induced when a conductor moves back and forth from the negative to the positive poles of a magneic field. So, a ring in an eqatorial orbit would not work. But a conductor in a polar orbit would induce some charge.
NASA tried this with the Shuttle once. One of the practicle problems was that the shuttle only completes one orbit every 90 minutes or so, which means that it moves from its most northerly position to its most southerly in about 45 minutes. This slow oscillation generates very little charge. The solution: a very long conductor. They spooled out a wire about 12 miles long.
This was in the late 1990's and, as I recall, when the wire was fully spooled out...it just kept going. Darn thing broke right off at the base with barely a pause!
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
