How Do Indices Function in Tensor Notation?
  • Thread starter Thread starter Miloslav
    Indices Tensors
Miloslav
I was wondering how the indices of tensors work. I do not understand how the indices of tensors in can be used. For example, \eta _{\mu \nu }, the metric tensor, is like a matrix, and x^{u} is a contravector. How does this extend to notations such as T{_{a}}^{bc} and T{_{ab}}^{c}?
use wraps to make the latex show up.<br /> <br /> The index notation is used in 2 ways. 1, it is used to denote the components of a tensor in some (arbitrary) coordinate system. And 2, it is often used to denote the tensor itself. The second way is a shortcut, but, strictly speaking, is an abuse of notation. <br /> <br /> Lower indices indicate covariance while upper indices indicate contravariance. The tensors you wrote at the end are respectively once covariant twicce contravariant and twice covariant once contravariant.
Ok. Thanks for the tip about Latex. I was hoping to clarify that tensors are used in a certain context. Thank you for the information, I now understand how it can be used, particularly in the case of the Kronecker delta.
In flat, Euclidean, space, in which we can use the Kronecker \delta as metric tensor, there is no distinction between "covariant" and "contravariant" tensors.
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
