magravat said:
P(3|0) =1/3 means for the probability of 0 events out of three happening is 1/3 I believe. There is proof of independence too.
Yeah I had a feeling you were using a non-standard notation: P(x|y) usually denotes a conditional probability.
Note: usually, if three things (numbered 1..3) can happen, then the probability that one will happen in one trial is 1/3 but the probability that
none of them will happen is 0. If "none of the above" is to be included as one of the possible events, then the probability that it happens is 1/4... since there are now 4 possible events. (Assuming independence and all events equally likely.)
So either your method is incorrect or the description of what it is intended to say is incorrect. Can you provide a practical example to illustrate your method?
To the other reply about it simplifying by the derviatives using limits, it does simply to something like that that I have derived before.
I did not use any limits or derivatives to perform the simplification - just normal algebra. Perhaps it is just unfamiliarity with English but the way you use these words suggests you don't know what they are normally taken to mean in mathematics. Practical illustration is probably the best way to deal with this.
I notice that your solution:
7.105e-15 hence reciprocal is close but different from combinations method of:1/1.407X10+14
is nothing like the actual one of 7.1511e-08 ... you are 6-7 orders of magnitude too small.
The sums do not add up enough to make up the difference. But it is not clear that you are working OPs problem.
So here's the suggestion: work through your method, step-by-step, for the problem of getting 6 numbers correct out of six trials selecting without replacement out of 49 possibilities and regardless of the order. We'll see if the result comes out the same as the combinations method, ad also gain an understanding of what your method actually entails. Would you do that for us?
