Apparent inductance vs. incremental inductance
  • Thread starter Thread starter CheyenneXia
    Inductance
Apparent inductance is defined as the ratio of magnetic flux (Phi) to current (I), while incremental inductance is the rate of change of flux with respect to current (dPhi/dI). Incremental inductance is used for small changes in current or voltage, whereas apparent inductance applies to larger changes. In non-linear systems, incremental inductance can differ significantly from apparent inductance, potentially being negative, which can lead to instability in devices like fluorescent lamps without a ballast. The discussion highlights that total inductance is not simply the sum of apparent and incremental inductance, as they represent different concepts in non-linear contexts. Understanding these distinctions is crucial for managing electrical systems effectively.
CheyenneXia
I only know that apparent inductance = Phi/I, incremental inductance = dPhi/dI.
Two definitions because of the non-linearity of Phi vs. I curve.
So is there anyone who can tell me when I should use incremental inductance and when apparent inductance?
Many thanks.
Use the incremental when there are small changes in the current or applied voltage and you are interested what happens because of it.
So does it mean small changes in current, incremental. Big changes, apparent.
I guess if phi vs. current is linear, incremental should be equal to apparent. Then why not incremental all the time?
Thanks.
The incremental can be very different.
In fact it can actually be negative. An arc lamp is like this. For example a lamp might have 100 Volts and 1 Amp flowing through it. So if it were a resistor it would have an apparent and incremental resistance of 100 Ohms. This is an incandescent light bulb.
Have you ever wondered why a fluorescent lamp needs a ballast? A fluorescent lamp might also be made to operate at 100 Volts and 1 Amp. But it would explode without a ballast while the incandescent lamp doesn't need it.
The answer is because the fluorescent lamp has a 100 Ohm apparent resistance and perhaps a -50 Ohm incremental resistance.
Imagine what that means if the lamp flickers for a second and draws a bit more than 1 amp. It's total resistance will decrease making it draw yet more current. It will in fact run away and explode. The ballast provides positive incremental impedance so that the sum of lamp and ballast incremental resistance is never negative.
Hey, I think I get it. Apparent inductance is like DC current while incremental inductance is like the small fluctuating AC current superimposed on the DC current. Am I right?
So the total inductance should be apparent+incremental?
Not really. Total inductance differs from incremental inductance in the same way as the gradient of a line from a point at the bottom to the top of a mountain differs from the slope of a particular bit of the track going up.
Basically, if the incremental inductance is not the same as the 'apparent inductance' then the device is non-linear and will introduce distortions into a large signal.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
