How Many Swaps Can Bubble Sort Take for Six Items?
  • Thread starter Thread starter phospho
    Algorithm
The maximum number of swaps needed to sort a list of six items using the bubble sort algorithm is 15, calculated by summing the series of swaps required for each pass. This is derived from the formula (n-1) + (n-2) + ... + 1, which simplifies to n(n-1)/2. The discussion emphasizes that in a worst-case scenario, sorting an array from highest to lowest requires the same number of swaps. A practical example in Java syntax illustrates this concept with an array of natural numbers. The thread concludes that understanding this series can help generalize the swap calculation for any number of items.
phospho
Q: Find the maximum number of interchanges needed to sort a list of six pieces of data using the bubble-sort algorithm
working:
for the first past, maximum needed is n-1 swaps where n is the amount of the pieces of data
2nd - n-2
3rd - n-3
4th - n-4
5th - n-5
so generally it takes
(n-1) + (n-2) +... (n-(n-1))
is this correct? It works for six as the it will be a maximum of 15 swaps, also how can I generalise this?
This would be more suitable for the computer science section, but hey ill help.
Consider an array of natural numbers ( I'll be using some java syntax here to provide a practical example ) :
int[] nums = {0,1,2,3,4,5,...n};
and presume you want to sort it from highest to lowest ( So we have a worst case scenario here ).
There are n elements in the array, so to move 0 to the nth position would require n-1 exchanges.
The next exchange for 1 would require n-2 exchanges.
This continues until you have n-(n-1) exchanges since n-n would be redundant because the list is sorted at that point.
I suppose a way you could generalize this would be to say :
\sum_{k=1}^{n-1} (n-k)
Cheers,
btw I had no idea it was the wrong section, in the UK, this is under our maths syllabus and we're not programming anything, but I can see how it leads to things :)
thanks again.
There's a trick to adding up an incrementing series of numbers, arrange the numbers forwards and backards and add up the sum:
Code:
n-1 + n-2 + n-3 + ... +   1
  1 +   2 +   3 _ ... + n-1
  n +   n +   n + ... +   n
This sum equals n (n-1), but since the array was added twice divide by 2:
(n-1) + (n-2) + (n-3) + ... + 1 = n (n-1) / 2
