How to go about solving this first-order nonlinear differential equation?
Yondaime5685
I saw this post at stackexchange:
The fact that curve length is fixed amounts to a functional constraint. So we need to use both the Euler-Lagrange equation and Lagrange multipliers. The functional to minimise is \int^a_{-a}(2\pi y-\lambda)\sqrt{1+y'^2}dx, where λ is a Lagrange multiplier. For this functional, the first integral of the Euler-Lagrange equation gives a different ODE from what I got above, which has the solution y(x)=k(\cosh\frac{x}{k}-\cosh\frac{a}{k}) for some k depending on l, as required.
I ran across this post when trying to solve a homework problem. But I have no idea how he got that solution for that. When I use the Euler-Lagrange, I get this diff eq below.
Here is the simplest form I have managed to get it in:
\frac{\alpha}{2\pi}=\frac{\eta \quad \dot{\eta}^2}{\sqrt{1+\dot{\eta}^2}}-\sqrt{1+\dot{\eta}^2}
Where \alpha is a constant. For the simplification, \eta = (y-y_0) & λ \equiv -2\pi y_0 is used from the quote above.
I don't know where to even begin to solve this. Any help would be good.
Thanks.
-edit
Some details that I thought I should add.
Since h=f+\lambda g≠h(x), I used the special case of the E-L equation:
\dot{y}\frac{\partial h}{\partial \dot{y}}-h=const.
But after the substituions to trim it up the special E-L turns into this:
\dot{\eta}\frac{\partial h}{\partial \dot{\eta}}-h=const.=\alpha
Where h now is: h=2\pi\eta\sqrt{1+\dot{\eta}^2}
That should be <br /> \frac{\alpha}{2\pi}=\frac{\eta \dot{\eta}^2}{\sqrt{1+\dot{\eta}^2}}-\eta\sqrt{1+\dot{\eta}^2} = \eta [\frac{\quad \dot{\eta}^2}{\sqrt{1+\dot{\eta}^2}}-\sqrt{1+\dot{\eta}^2}]<br />
Then you square the equation: <br /> (\frac{\alpha}{2\pi})^2= \eta^2 [\frac{\quad \dot{\eta}^4}{1+\dot{\eta}^2} -2 \dot{\eta}^2 + 1 + \dot{\eta}^2] = \eta^2 [\frac{\quad \dot{\eta}^4}{1+\dot{\eta}^2} -\dot{\eta}^2 + 1]<br /> <br /> \\ (\frac{\alpha}{2\pi})^2= \eta^2 \frac{\quad \dot{\eta}^4 -\dot{\eta}^2(1+\dot{\eta}^2) + (1+\dot{\eta}^2)} {1+\dot{\eta}^2}<br /> = \eta^2 \frac{\quad \dot{\eta}^4 -\dot{\eta}^2 - \dot{\eta}^4 + 1+\dot{\eta}^2} {1+\dot{\eta}^2}<br /> = \eta^2 \frac{1} {1+\dot{\eta}^2}
I assume you can continue from here.
Thanks a lot! That made the problem a lot simpler.
I can't believe I didn't carry that \eta over.
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
