billiards said:
I once watched a video lecture on youtube about rainbows. The lecture was by Walter Lewin, it was one of the best lectures I have ever seen... if you have the time I thoroughly recommend it: http://video.google.com/videoplay?docid=-2978729867097229598
For some reason, that video won't play on my laptop.
I think this may be the same lecture:
https://www.youtube.com/watch?v=6QVbE_tU2sA
Almost two hours to explain how a rainbow is formed!
I watched the whole thing.
Anna,
I think this might be a bit difficult to explain to a fifth grader without several visual aids.
I would first explain what the 42° angle means using the rainbow drop from Evo's link:
Then you would have to explain that rainbows are made up of the light reflected through millions of raindrops, and the only time they will see the rainbow is when their eyes, the raindrops, and the sun, make a 42° angle.
That, along with Descarte's image:
might seep into their heads why rainbows are circular.
I just did an experiment trying to show this, and saw something that I could not explain.
I saw two rainbows that intersected at almost a 90° angle.
A bit hard to see. And I scratched my head for a minute or two trying to figure it out, as this type of phenomena could only be explained if there were two light sources.
So I turned around and noticed that one of my car's rear windows was reflecting light, out of line with the sun, and explained the second light source.
But I thought that would make a fun experiment.
Get the class together on a sunny morning with several mirrors in different locations all reflecting sunlight onto a single area, then spritz the air with a water hose mister or a spritz bottle, and see how many different rainbows you could see.
ps. Rainbows are best viewed against a black background. I discovered this after watching Lewin's video last year and spending hours and hours trying to get good images of one. Science is half knowing how things work, and half experimenting with that knowledge to get a good picture.
pps. As to why there are colors in a rainbow requires a knowledge of
refraction, of which I have no knowledge.
