Copper Plating Mystery: Solve the Puzzle!
  • Thread starter Thread starter Flyingwing12
    Copper Mystery
The discussion centers on the unexpected results of copper plating using a copper sulfate solution in vinegar, where wire brushing certain metals leads to a strong, semi-gloss copper bond that is difficult to remove. In contrast, conventional electroplating yields poor adhesion, particularly when using "dirty" copper as the anode. The wire brushing likely enhances surface preparation by removing oxides and increasing surface area, which may improve bonding. Additionally, the type of metal being plated could influence the copper's affinity for adhesion. Further experimentation is suggested to explore these intriguing findings and their implications for plating techniques.
Flyingwing12
I had a solution of copper sulfate in (vinegar) and noticed that when I wire brushed certain metals, the copper made a beautiful arrangement on the work piece, often a perfect semi-gloss. The copper is also seemingly bonded to the metal ( can't wipe it off).
However, when I use conventional electroplating with the solution, the copper just barely hangs on the surface of the work. And with " dirty " copper as the anode, the result is very poor.
So why does this happen? I thought it was the wire wheel depositing a huge positive charge on the work ( which is a pair of pliers with insulated handles. ;) ).
Very interesting indeed.
Wire brushing also dramatically changes the surface characteristics doesn't it?
Though, to me, your photo just looks rusty.
Interesting. :smile: This might be better placed in the Chemistry subforum, being quite appropriate for industrial chemists.
I don't have a whole lot of experience with electroplating, but as Simon alludes to, electroplating is highly sensitive to surface preparation. When you wire brush, you're probably removing surface oxide along with any protective coating. Applying a degreaser (and scrubbing) also goes a long way towards removing oils, grease, and grime (which also 'mask' the surface, preventing deposition).
Still, if you hit the "Report" button, you can summon a moderator and get them to move your post over to Chemistry.
After reading your description of the copper plating mystery, it seems that the wire brushing process is creating a stronger bond between the copper and the metal surface compared to conventional electroplating. This could be due to the mechanical action of the wire brush, which may clean and roughen the surface, providing more surface area for the copper to adhere to. It is also possible that the wire brush is creating a more positive charge on the metal, allowing for better bonding with the copper ions in the solution.
Another factor to consider is the composition of the metal being plated. Some metals may have a natural affinity for copper, making it easier for the copper to bond and form a strong arrangement. Additionally, the use of "dirty" copper as the anode may also affect the plating process as it can introduce impurities into the solution.
Further experimentation and analysis would be needed to fully understand the mechanisms at play in this copper plating mystery. It is always exciting to discover new and unexpected results in scientific experiments, and your findings may open up new possibilities for improved plating techniques in the future.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
