What is the physics behind the functioning of thermocouples?
  • Thread starter Thread starter krackers
    Work
Thermocouples operate based on the thermoelectric effect, where a voltage is generated due to temperature differences between two different metals. The use of two distinct metals is crucial because they have different thermoelectric properties, which allows for the generation of a measurable voltage when subjected to a temperature gradient. If hot and cold charge carriers diffuse at equal rates, there is no net charge movement, resulting in no potential difference. However, impurities and lattice vibrations disrupt this balance, causing carriers to diffuse at different rates and creating an electrostatic voltage. Understanding these principles is essential for conducting experiments with thermocouples.
krackers
Hello there! I am planning to do an experiment on thermocouples but have a few questions.
1. What is the physics behind why the thermocouple works?
2. Why do two different metals need to be used for making this?
Thank you!
Science news on Phys.org
Do you understand what a Fermi surface is?
No, I do not.
However, I did look through wikipedia and I think I might have found a section that pertains to my question. [http://en.wikipedia.org/wiki/Thermoelectric_effect#Charge-carrier_diffusion]
The part I am not clear on is this. [Taken from that article directly]
"If the rate of diffusion of hot and cold carriers in opposite directions is equal, there is no net change in charge. The diffusing charges are scattered by impurities, imperfections, and lattice vibrations or phonons. If the scattering is energy dependent, the hot and cold carriers will diffuse at different rates, creating a higher density of carriers at one end of the material and an electrostatic voltage."
Why would there be no potential difference if the rate of movement of the hot/cool electrons is equal? Why are two different metals necessary? Why would impurities, imperfections, lattice vibrations, or phonons make them diffuse at different rates, and how does that end up creating an electrostatic voltage?
