Question about expectation values.
cragar
Is it possible to define operators to find the expectation value of position for a Gaussian wave packet. Similar to finding raising and lowering operators for the harmonic oscillator in terms of position and momentum and then using those to find <x> and <p>. But I was just wondering if this could be done for a Gaussian wave packet.
Here is one: X
If your wave packet is expressed as function of position, ##<X> = \int \psi \psi^* x dx##.
I don't completely understand what you are doing? Is X my new operator.
are you starting with the definition of expectation value and then going from there.
The position operator (in the position representation) is simply ##x##. So the general definition of expectation value:
$$\langle A \rangle = \int {\Psi^* A_{op} \Psi dx}$$
becomes
$$\langle x \rangle = \int {\Psi^* x \Psi dx}$$
Plug in your wave function and grind out the integral.
ok i understand that. I was trying to think of a way to compute that without doing an integral. Like how you can do that for the harmonic oscillator with a+ and a -
like &lt;x&gt;=&lt;U|a^+ + a^-|U&gt;
u is the wave function and a+ is the raising operator.
can I do this for a Gaussian wave packet.
If you define appropriate operators.
For a gaussian wave packet, the expectation value of the position is the central value of the distribution. If you know that, you are done.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
