Where Do Points Sum to Two-Thirds the Perimeter of a Rectangle?
Numeriprimi
I found one interesting example...
We have a rectangle ABCD with his perimeter o. Where is the set of points when their (for each point) sum of distance lines AB, BC, CD, DA is 2/3o ?
I tried it, but geometric problems is quite hard for me and I don't know how do it. So, have you got any idea?
Sorry, Numeriprimi, I don't understand. :confused:
I think the problem is to identify the set of points X such that
d(X,AB)+d(X,BC)+d(X,CD)+d(X,DA)= \frac{2}{3}*\text{Perimeter of Rectangle ABCD}.
The distances on the left hand side are lengths of perpendiculars dropped from the point X to the corresponding line. For example, if X lies inside the interior, then the left hand side would equal (1/2) the perimeter. So the locus cannot include points inside the rectangle. Without doing an explicit calculation, I bet the answer is an octogon.
Sorry for my English... And Vargo, yes, I mean this, thanks for wrote it in better form :-)
Thanks, Vargo! :smile:
Numeriprimi, divide the exterior of the rectangle into 8 sections (by extending the sides),
and consider each section separately …
you should be able to find an easy equation for each section. :wink:
(and yes, it's an octagon!)
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
