Good ideas concerning shortening and lengthening electrical impulses
  • Thread starter Thread starter freddyfish
    Electrical Ideas
The discussion focuses on modifying electrical impulses from a steady source without changing its settings. The goal is to shorten one impulse by 5 ns while lengthening another by the same amount, using two branches with high-impedance instruments. Suggestions include using coaxial cable as a delay line and employing additional circuitry to generate the desired pulses. Pulse compression techniques were mentioned, although they typically apply to short or high-energy pulses. Ultimately, the original poster resolved their issue based on the feedback received.
freddyfish
Hey
Basically, what I am wondering is if anyone has any great ideas how to change the electrical impulses from an impulse source giving steady pulses if you can't change the settings of the source.
What I would like to do is make send these impulses through two separate branches (they share the same impulse source) and shorten one impulse by 5 ns while lengthening the impulse through the other branch by the same amount. Each one of these branches contain an instrument with high impedance, and also I would like to avoid reflections in the circuit. The impulses are square waves with amplitude of order a few volt and the period is, say, 15μs.
Thanks
You should really ask this in the electronics sub forum. Do you care about the pulse amplitude? If you don't and if your signal is large enough, you could split the signal and try to put a meter of coax cable (look at your cable specs to get 5ns) as a delay line, then combine the signals again using an or-gate and an and-gate. In theory these speeds should be possible. But there are probably more elegant ways to achieve this.
freddyfish said:
Hey
Thanks
(Thread moved to the EE forum)
Can you just use the signal source as a trigger for a separate circuit that generates the 2 pulses that you want?
Same reaction: add the circuitry, if it's a matter of 5ns.
Things like pulse compression exist, but are meant for very short pulses or for very high energy. As well, users don't expect nice waveforms from these circuits.
Thank you all for your answers. Everything is now solved, so the problem is eliminated.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
