Stopping discharging a battery during charging
  • Thread starter Thread starter adilsyyed
    Battery Charging
To manage a lead acid battery-powered light during frequent power outages, a relay can be used to automatically turn off the light when charging begins. This setup requires a "break-before-make" relay to ensure the light disconnects from the battery when the charger is engaged. The relay should be powered by the wall outlet, allowing it to switch between configurations for charging and discharging. Users are encouraged to research relays further to understand their operation better. This solution provides a practical way to maintain light during outages while preventing battery discharge during charging.
adilsyyed
I am from a country where power outage is very common.
I have a light source which is run by a lead acid battery. At night, I want to keep this light ON during power outage and when the electricity is back on, the charging circuit engages and the lights should turn off itself.
I am guessing an arrangement would be needed so that when the charging starts, with it somehow, a circuit should sense it and open/dis-engage the discharging circuit.
Simple Version:
I want to plug the charger in the battery, during power outage the light will be ON and with power on (when the charger starts charging the battery), the light turns OFF.
Simple Version:
I would use a relay powered from the wall power. You can connect your light and charging circuit to different parts of the relay to give the two different configurations.
ummm... That would be a nice way to do it.
Be sure to use a "break-before-make" type of relay. :smile:
If only I was expert in electronics.
But thanks for the head start, that's how we learn. I am going to read more about the relay you proposed.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
