Proof of "If f(x) is Continuous, then |f(x)| is Continuous
  • Thread starter Thread starter macca1994
    Continuity
macca1994
I have seen this theorem in a few books, but none of them give proofs, it says
if f(x) is a continuous function then lf(x)l is a continuous function. What is the proof of this because i don't really understand why this holds, thanks
The function |~|:\mathbb{R}\rightarrow \mathbb{R} is continuous. Composition of continuous functions is continuous.
It makes sense though.
Consider y=-1/x : its continuous in the domain of x in (0,infinity) right?
and its counterpart z=|-1/x| = 1/x is continuous in the same domain for x
Ahh, yeah i get that, but can you not prove it without using composition of two functions?
i might pm him, cheers
It is very easy to prove using the \epsilon-\delta definition. Are you familiar with \epsilonand \delta definitions?
yeah, that's about the limit of my analysis knowledge, how would you use the ε,δ definition?
No need micro can handle it too. I think the epsilon / delta is the weierstrass definition.
Take an a\in \mathbb{R}. You will need to prove
\forall \varepsilon >0: \exists \delta >0: \forall x: |x-a|<\delta~\Rightarrow ||f(x)|-|f(a)||<\varepsilon
You are given that f is continuous in a, thus:
\forall \varepsilon >0: \exists \delta >0: \forall x: |x-a|<\delta~\Rightarrow |f(x)-f(a)|<\varepsilon
So, take \varepsilon>0 arbitrary. Take \delta>0 as in the previous definition: so it holds that
Take an x arbitrary such that |x-a|<\delta. Then we know that
||f(x)|-|f(a)||\leq |f(x)-f(a)|<\varepsilon
So we have verified that ||f(x)|-|f(a)||<\varepsilon and thus we have verified that \varepsilon-\delta definition of continuity. Thus |f| is continuous.
ah that makes sense and is very obvious, do you need to show that limit of lf(x)l is in fact lf(a)l or is that just obvious?
I've just proven that here. It's because |f| is continuous in a.
oh okay, i get it, thanks for the help
Are you trying to prove this for a class or so that you understand it? Judging from your posts, I don't think that you understand the epsilon-delta statements.
Many calculus teachers give the intuitive rule "if you can completely draw the graph of f on an interval without lifting your pencil, then f is continuous on that interval." This is true, and it will work if you are given an f for which the antecedent is true. (In your case, you're not given a particular f, so this rule would not lead to a proof, even on an informal level.)
However, mathematicians do not care about continuous functions because they appear to be connected; they study continuous functions because continuous functions enjoy the property that small changes in input do not significantly affect their outputs. That is, if we want our function outputs to be within some margin of error ε about the function value f(y), we can always bound an interval of radius δ about y so that if we choose any input in the interval (y-δ,y+δ), we are guaranteed to have an output within the interval (f(y)-ε,f(y)+ε). Any function that enjoys this property is continuous at y.
Sorry if I'm telling you something you already know, but I have had far too many students who still equate continuity with connectivity because teachers of the calculus never tell the students the true importance of continuous functions. I thought I'd better intervene before you settled on what continuity means in your mind.
