What Size I Beam for 5m Roof Span Supporting 20,000 kg?
  • Thread starter Thread starter escobar147
    Beam
For a roof span of 5 meters supporting a total weight of 20,000 kg, the design requires careful consideration of structural support and local building codes. The discussion emphasizes the need for additional information regarding the foundation, perimeter structure, and potential use of steel or wood framing. It is crucial to consult a licensed structural engineer to ensure safety and compliance with regulations. The conversation also highlights that structural design is complex and not suitable for DIY projects. Proper professional guidance is essential to avoid safety risks.
escobar147
I am designing a roof which is 5 metres wide and 10 metres long. the total weight it has to support is 20,000 kg.
there will be two I beams spanning the 5 metre width, each i beam is 3.33m apart.
what dimensions should i use for my i beam?
any help would be massively appreciated, is there an industry standard beam for this type of project?
Need more info.
I'm not quite sure the application or if this is just a problem from your homework.
But there is a lot that goes into structural design and we need more information about what you're setting it on and your perimeter structure. Is it sitting on masonry wall? what kind? is it going to be secured mid span to a girder? Is the roof pitched? What is the other structural information? Most likely for things like this, you would have a square steel (i-beam) frame around the perimeter and use metal joists to span the short distance at approximately 1.5m-2m on center. If its allowed by your local code, you may also wind up using wood trusses & girders. You get the joist size, by taking the length of the longest unbraced portion of the beam, its dead and live loads for the area its supporting, and the load it has to support. You have to account for wind loads, uplift forces and resistances and how much beams/joists are allowed to deflect.
Normally, you would have to get this work permitted and have the stamped of a licensed structural engineer for it. Could you give some more information?
Assuming this is a real project, stop what you are doing and contact a local civil/structural professional engineer. You are out of your element. Do not put people in danger due to your ignorance.
If this is a homework problem, please state so. I think there is a different forum for that.
agreed
/Agreed. Structural steel is not a Do It Yourself home project.
Good advice. Thread closed.
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
