Continuity of the Bezier Curve, Question
  • Thread starter Thread starter mymachine
    Continuity Curve
The discussion centers on the continuity and smoothness of two cubic Bezier curves, A and B, particularly at the junction where A3 meets B0. For the curves to be smooth at this point, the segments A2-A3 and B0-B1 must be collinear, ensuring that their slopes match. While A3 and B0 can be the same point, they do not need to be midpoints of the segments. Both curves are described by 3rd-degree Bernstein polynomials, confirming their classification as cubic Bezier curves. The overall conclusion is that while the curves can be continuous, they may not be smooth without the specified conditions.
mymachine
Hi everyone,
I would like to ask about the continuity of the cubic Bezier curve.
There are two cubic Bezier curves, A and B, shown as below two images:
The coordinates of the A curve are:
A0 = (x0,y0) = (0,0)
A1 = (x1,y1) = (2,3)
A2 = (x2,Y2) = (5,4)
A3 = (x3,y3) = (7,0)
The coordinates of the B curve are:
B0 = (x0,y0) = (0,4)
B1 = (x1,y1) = (3,1)
B2 = (x2,y2) = (7,0)
B3 = (x3,y3) = (9,8)
If I join these two curves together by connecting the point A3 and B0, it looks such as below image:
However, the curve doesn't looks smooth at point A3 = B0.
The question is, what is the equation of the Bezier curve start from
point A0 > A1 > A2 > A3=B0 > B1 > B2 > B3
where the endpoint is A0, A3 = B0, and B3
and so that the curve is continue and looks smooth?
Also, does this A+B curve is 7th degree of the Bernstein polynomial?
Thank you
Mathematics news on Phys.org
Is it possible if
A2, A3 = B2, and B1
are not colinear
and
A3 = B2
is not the midpoint of A2 and B1?
Hi, mymachine,
yes (more or less): the points A2, A3 = B0, and B1 should be collinear. This is because the curve "A" is tangent at A3 to the straight segment A2-A3, and the curve "B" is tangent at B0 to the segment B0-B1. If these two slopes on the curves are to be the same, the segments A2-A3 and B0-B1 must have the same slope too. And since A3=B0, this puts these points on the same straight line.
The two segments A2-A3 and B0-B1 do not need to have the same length (that is, A3 = B0 does not need to be a midpoint of A2-B1).
Your last question, I couldn't understand. The Bernstein polynomials that constitute both the "A" and "B" curves are 3rd-degree polynomials (which is why these are called "cubic" Béziers).
(Just as a side comment, mathematicians use the word "continuity" to refer to the fact that, in your example, A3 = B0; that is, that you didn't need to lift the "pencil" to continue drawing, that the curve does not have a "hole" because of A3 and B0 not coinciding.) Your curve, as described, is continuous; it's just not smooth.
Hope this helps!
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
