IR thermometer pointed up into a cloudy sky?
The discussion centers on the thermodynamics of human body heat regulation in relation to environmental temperatures, particularly when pointing an IR thermometer at the sky. It highlights that the sky generally acts as a heat sink, with measurements indicating that an overcast sky is significantly cooler than the human body. The cooling effect of evaporative cooling is emphasized as a more substantial factor in preventing overheating, especially in low humidity conditions. The concept of wet bulb temperature is introduced as a key determinant for the effectiveness of evaporative cooling. Overall, while the sky's temperature plays a role, evaporative cooling is identified as a more critical mechanism for heat regulation.
Spinnor
A physics stack question asks why when the air is hotter then your body thermodynamics allows your body to operate as a heat engine as a heat engine must have a sink for waste heat. See question here,
http://physics.stackexchange.com/questions/59316/human-as-a-heat-engine
Part of the answer is that normally the sky (except for the sun) is a net heat sink not a net heat source, if we point our hands to a clear sky our palms would sense cold? A clear sky is even colder then an overcast sky? Other fun with an infrared sensor?
Edit, point your hands towards the sky and away from the sun for a cooling effect?
With infrared thermometer in hand I measured plastic tarp in the shade, the overcast sky, inside my mouth. The outside temp was 47F in the shade by a standard thermometer.
plastic outside in shade, 48F
overcast sky (cloud ceiling at 7500ft), 19F
inside of my mouth, 97.7F.
So part of what keeps us from overheating is the fact that the sky is relatively cool?
Thanks for any help!
Science news on Phys.org
I doubt that's a significant portion of it. A much, much larger factor is the fact that evaporative cooling effectively allows you to use warm air (even if it's warmer than your skin) as a heat sink, so long as the humidity is relatively low. Specifically, look up the concept of the wet bulb temperature - that defines the lowest attainable temperature using evaporative cooling in a given environment.
I was doubting along with you so did some Goggling,
https://www.google.com/webhp?hl=en#...42,d.dmg&fp=e67612c481f66f1f&biw=1093&bih=491
first listing,
http://books.google.com/books?id=n5...q=how much power does a human radiate&f=false
seems to say otherwise on page 192,
"A naked human will radiate as much energy as 13 100W light-bulbs"?
That is off a bit as they use 98F as the surface temp of a naked human. I'm topless and have a surface temp of 84F belly, 92.2F arm, 93.4 back.
Using 88F body temp in their calculations with room walls at 73F I get a net power radiated 1150W - 940W = 210W for a naked person in a 73F room?
So probably still small compared to the heat that can be removed by evaporative cooling and conduction?
9K
88K
