What Are the Uses of RC Filters in Advanced Circuits?
  • Thread starter Thread starter potatocar
    Resistors
Resistors are essential in circuits for controlling voltage and current, allowing different components to operate effectively with the same power supply. They create voltage drops and can dissipate energy as heat, which is useful in applications like light bulbs and soldering irons. While resistors do consume energy, they are necessary for managing current flow, especially in low-resistance circuits where adjusting voltage alone is insufficient. Additionally, resistors play a crucial role in RC filter circuits, enabling the filtering of specific frequency bands in advanced applications. Understanding these functions highlights the importance of resistors in circuit design and operation.
potatocar
I don't understand why we use resistors at all. I've read that they cause a voltage drop and decrease the flow of electrons (current). Why is this useful? If we want to decrease the current, why not just lower the voltage? Don't resistors just waste energy?
And how will you lower the voltage at different points in a circuit?.
bp_psy said:
And how will you lower the voltage at different points in a circuit?. .
So it's only because the same voltage supply is used for different "things" (that require different currents to flow through them)?
Also notice that ohms law gives very high currents for very low resistances even if your voltages are low. Of course ohm law doesn't always hold but it still gives you a good idea
Do you mean if R<1? So.. a resistor can increase the current?
Yes the main use of resistors is voltage control and current control.
http://en.wikipedia.org/wiki/Current_divider
http://en.wikipedia.org/wiki/Voltage_divider
The current always decreases with increasing R. What I meant was that it would be very hard to adjust the current in a low resistance circuit just by adjusting the voltage. I edited that out because It might be confusing and maybe not a very useful way to think about it.
Resistors are also useful in generating heat. For a current I through a resistance R, the powerloss is P = I2R which manifests itself through heat (this is how circuits overheat and stop working or burn). Using this idea, you can use this heat in applications such as light bulbs, electric stoves, soldering irons and so on.
A perfect circuit would encounter zero resistance. Love to see somebody build it. You would be a trillionaire. Power my AC with no resistance LOL
