Molecules under high electric field
pierebean
Hello fellow physics lovers,
I wish to predict the behaviour of a organic molecule under an electric field (High Voltage). I wish to know how much E-field can this molecules withstand before being fragmented.
Can anyone point toward a freeware than might compute such a field?
It is important to consider that the molecule will be fragmented by E-field and not by accelerated electron collisions (like in Mass Spectrometer for instance).
Thank you for your suggestions.
Strictly speaking, any constant electric field will lead to autoionization, however, the lifetimes can be very long as the electrons have to travel through a wide barrier at low field intensities. So the autoionization rate will increase exponentially with the field strength and you cannot define a well-defined threshold.
Thank you for pointing this out. Indeed, many phenomena in physics are usually not discrete (currently I'm only thinking of phase transition which almost is). However, if this auto ionization phenomenon is described by a exponential, one might define a semi-threshold (actually an order of magnitude is enough for my application) at which the probability of ionization is say greater that 90%.
In my application, I have anchored carbon chains on a substrate which is under a high electric field.
I want to have some idea of the E-field that might break the bound of the carbon chain. But I am also interested at their behaviour under any arbitrary field (stress, change of structure ect..) before breaking out.
Does such a program/software exist to perform this study?
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
