Is Mechanical Angular Momentum Conserved in a Magnetic Field?
Spinny
We have a particle with electric charge e that moves in a strong magnetic field B. The particle is constrained to the (x,y)-plane, and the magnetic field is orthogonal to the plane, and constant with B as the z-component of \mathbf{B}.
Furthermore we have the rotationally symmetric form of the vector potential,
\mathbf{A} = -\frac{1}{2}\mathbf{r}\times \mathbf{B}
the relation between between velovity and momentum
\mathbf{v} = \frac{1}{m}\left(\mathbf{p}-\frac{e}{c}\mathbf{A} \right)
and the Hamiltonian
H = \frac{1}{2m}\left(\mathbf{p}-\frac{e}{c}\mathbf{A} \right)^2
We now have to show by use of the equation of motion that, generally, the mechanical angular momentum
L_{mek} = m(xv_y-yv_x)
is not a constant ot motion, whereas
L_{mek}+\left(\frac{eB}{2c} \right)r^2
is conserved.
I'm really not sure where or how to start. Do I have to use the Lagrangian and the Euler-Lagrange equation? If so, how do I find out wether or not any of these expressions are constants of motion or not? Or am I way off?
Edit: minor correction to equations.
I don't know what you mean in your first equation by taking the cross product of 1/2 and B, but to answer your question, generally conserved quantities arise when the langrangian (or hamiltonian) is symmetric with respect to a change with one of the coordinates. Conservation of angular momentum comes from symmetry in rotations, ie, in the coordinate theta. Find a system of coordinates such that there is some theta-like coordinate with respect to which the lagrangian is invariant.
First off, I've corrected the first equation, now it hopefully makes more sense :smile:
Second, I'm afraid it didn't help me much, the rest of your post. You see, this is really a quantum mechanical course, so I'm a bit surprised we got a problem like this. Anyway, I don't know how to find "a system of coordinates such that there is some theta-like coordinate with respect to which the lagrangian is invariant", or even where to begin with all this. I don't think this is supposed to be such a difficult problem, but then again, everything is relative :wink:
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
