Is Spacetime a Fluid Like Ether in Black Hole Analogies?
lwymarie
An ECHO of Black Holes
Sound waves in a fluid behave uncannily like light waves in space. Black holes even have acoustic counterparts. Could spacetime literally be a kind of fluid, like the ether of pre-Einsteinian physics?
By Theodore A. Jacobson and Renaud Parentani
When Albert Einstein proposed his special theory of relativity in 1905, he rejected the 19th-century idea that light arises from vibrations of a hypothetical medium, the "ether." Instead, he argued, light waves can travel in vacuo without being supported by any material--;unlike sound waves, which are vibrations of the medium in which they propagate. This feature of special relativity is untouched in the two other pillars of modern physics, general relativity and quantum mechanics. Right up to the present day, all experimental data, on scales ranging from subnuclear to galactic, are successfully explained by these three theories.
Nevertheless, physicists face a deep conceptual problem. As currently understood, general relativity and quantum mechanics are incompatible. Gravity, which general relativity attributes to the curvature of the spacetime continuum, stubbornly resists being incorporated into a quantum framework. Theorists have made only incremental progress toward understanding the highly curved structure of spacetime that quantum mechanics leads them to expect at extremely short distances. Frustrated, some have turned to an unexpected source for guidance: condensed-matter physics, the study of common substances such as crystals and fluids...
What do you think about it?
1. Please pay attention to the different forums we have in PF. This topic belongs either in SR/GR or General Astronomy.
2. When you are copying stuff off some sources, please CITE THE SOURCE clearly. If not, you are plagarizing, or worse still, violating copyrighted material, such as the one from this site:
http://www.sciam.com/article.cfm?articleID=000ADA62-D854-137C-962A83414B7F0000
Zz.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
