What is the pattern in this sequence and can it be proved?
  • Thread starter Thread starter Natasha1
    Sequence
Natasha1
This is my question: Which powers of numbers in the sequence below are always in the sequence and which are not. Prove it?
Sequence: 2, 5, 8, 11, 14...
Answer:
So the gerenal term is 3n + 2
Now
(3n+2)^2 = 9n^2 + 12n +4
Where should I go from here?
Answer:
Now
(3n+2)^2 = 9n^2 + 6n + 4
I think that should be 9n^2 + 12n + 4
Conventionally, \mathbb{N} is the index set of sequence. This means that when identifying the general term, it must be that a1 is the first term in the sequence. The way you wrote an, a0 is your first term.
It's no big deal, it just avoids confusion.
I suggest you go back to your iniital problem before tacking this one as the method of proof is very similar and you're just one step away from the final solution in the other problem.
When you expand (3n + 2)^k into a polynomial, every term except for the constant term must be divisible by 3.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
