Tension and Forces on an Inclined Plane
  • Thread starter Thread starter Heat
    Angle Tension
The discussion focuses on calculating the tension in a rope connecting two blocks on a frictionless incline and the forces exerted by the incline on each block. Participants emphasize the importance of drawing free body diagrams and applying Newton's laws to solve the problems. The calculations involve expressing the tension and forces in terms of the weight (w) and the angle (alpha) of the incline. Specific cases are considered, such as when alpha equals 0 and 90 degrees, to interpret the results. The conversation highlights the need for understanding the relationship between the forces and the geometry of the incline.
Heat
Two blocks, each with weight w, are held in place on a frictionless incline.
In terms of w and the angle alpha of the incline, calculate the tension in the rope connecting the blocks.
In terms of w and the angle alpha of the incline, calculate the tension in the rope that connects block A to the wall.
Calculate the magnitude of the force that the incline exerts on each block.
Interpret your answers in part C for the case alpha = 0.
Interpret your answers in part C for the case alpha = 90 ^circ.
If possible express in terms of w and alpha.
I just don't know where to start, but to show my attempt I will try to think this logically.
The weight of the tension of block B affects it the rope much more than the weight of block a, both have a normal force perpendicular to the surface.
Draw free body diagram and apply Newton's laws.
ok I drew a fre ebody diagram for block b and a, but I don't know where to go from there... :(
ok, i solved the few questions in the beginning, now I am having problems with the magnitude.
magnitude is sqrt ( x^2 + y^2).
so I substitute the components in, if so how.nvm, I figured it out. :D
how do u find the magnitued. i was able to find the first 2parts on my own but I am not sure on how to calculate the mag.
For part 3, notice that
1. The force exerted by incline on the block is perpendicular to the surface.
2. Since there is no motion in the perpendicular direction to incline (block is not flying away!), total force in that direction is zero.
See if you can figure it out now.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
