The physics behind air/fuel ratios in 4-stroke engines.
The discussion centers on the relationship between air/fuel ratios and combustion temperatures in 4-stroke engines. It is established that the stoichiometric ratio typically produces the highest combustion temperatures, but operating at this ratio may not be optimal for engine performance or longevity. Lean mixtures can lead to higher temperatures under certain conditions, but excessive leaning can cause engine damage, such as melted pistons. The conversation highlights that while maximum exhaust gas temperature (EGT) occurs near stoichiometry, the best operational conditions for engines often lie outside this point. Ultimately, achieving complete combustion involves a balance of air and fuel, with various factors influencing the ideal mixture for efficiency and safety.
Holocene
Correct me if I'm wrong, but the hottest combustion temperatures will result when the air/fuel ratio is ideal, or stoichiometric, no?
I ask, because there seems to be this mentality that a lean mixture will result in even hotter temperatures, and could cause engine damage.
This has not been my experience. In aviation, Cessna recommends leaning the mixture until peak exhaust gas temperature is reached. Further leaning only reduced the EGT reading, it does not increase it.
What is the truth?
Science news on Phys.org
What is the truth?
As I understand, the stoichiometric ratio will give off highest heat, but in case all the fuel molecules combust. In fact, the molecules do not burn completely and some side reactions occur which reduce the temp and thus reduce the efficiency. So adding some more air will increase the chance of complete combustion, but we can not dilute the fuel forever. There should be an optimum mixture.
Not necessarily
Burning in excess air could ensure that al the fuel burns most completley to CO2 / H2O and so generate most energy.
But isn't a "most complete" combustion accomplished via a stoichiometric ratio as well?
I know what you're saying, but if the fuel hasn't completely burned, that is indicative of mixture that is too rich.
In a perfect world, but it depends on the reaction vessel and conditions - it's usually best to have one component in excess to guarantee the reaction goes to one end point. BUT on the other hand this will dilute the reaction products and so reduce the average temperature even if it generates most energy.
It's likely to need a very complicated model of the fluid dynamics in the cylinder, unfortunately.
Many engine tuners can attest to the fact that leaning out the mixture too far results in holes melted in the piston crown. I had a badly pinking engine once, turned out to be an air leak between carb & inlet... I can't say whether this is consistent with what you say about exhaust temperature reaching a peak. Keep in mind that the piston/valve/seat/head temperatures are not the same as the exhaust temp.
Not normally. For liquid fuels, evaporative effects help to cool the charge and end gas. Leaning the AFR off beyond stoichiometry can cause an increase in combustion temperatures because this cooling effect reduces.
In a quasistatic environment, yes. But in an internal combustion engine, breathing effects mean that it's impossible to completely burn all the fuel given stoichiometric conditions. Providing excess oxygen gives a greater possibility of complete combustion, but even this is not easily achieved.
Holocene
Yes the EGT is max at stoichiometric, or close to it, but it is the worse place to operate an aero engine. It gives you neither best power nor best economy. Auto engines operate close to it because it gives the lowest overall emissions.
If you look at the first page at the site below you can see how the EGT peaks. To the right of peak it is called “rich of peak” (ROP) and engine is fuel cooled. To the left of peak it is called “lean of peak” (LOP) and engine is air-cooled. People often make statements like: “A lean mixture runs hotter”. This statement may or may not be true. If you start off ROP and then lean – then yes the EGT will rise, but if you start off LOP and then lean – the temperature will drop and rise when mixture is richened.
http://www.lycoming.textron.com/support/troubleshooting/resources/SSP700A.pdf
I do not know the science behind it, but as someone mentioned before, running a car too lean has a tendency to melt/blow up/destroy car engines. I think it is important to keep in mind that there are a lot of other variables involved. I personally have seen 3 engines blown up because of improper air to fuel ratios(thankfully they weren't mine)
Thanks to nucleus for that link in post #8. A very interesting figure, worthy of a good look.
