What Is the Impact of Throat Velocity on Pressure According to Bernoulli's Law?
  • Thread starter Thread starter gerdsmit
    Law
Bernoulli's law indicates a direct relationship between pressure drop and fluid velocity at the throat, leading to questions about the implications of achieving a high negative absolute pressure through increased throat velocity. The equation suggests that if P2 is negative, it implies an increase in the original pressure P1. However, the concept of negative absolute pressure is nonsensical, as absolute pressures cannot be negative. Additionally, the maximum velocity achievable in any throat is limited to sonic velocity. This discussion highlights the theoretical boundaries and practical limitations of fluid dynamics.
gerdsmit
According to Bernouilli's law there is a direct relation between pressure drop and fluid's velocity at the throat. What would be the physical meaning of a high value negative absolute pressure that theoretically can be achieved by increasing fluid's throat velocity.
It would probably mean that the pressure experienced before the throat is increased,
In the eq P1 + 1/2DV1^2 = -P2 + 1/2DV2^2,
bring _p2 to the other side
=>P1+P2 + 1/2DV1^2 = 1/2DV2^2
(D=density,P1 = initial press.,P2=final pressure,same for V1 and V2)
implying that the original pressure is increased...
Hope you understand what I am trying to say...(good question though)
gerdsmit said:
According to Bernouilli's [equation] there is a direct relation between pressure drop and fluid's velocity at the throat. What would be the physical meaning of a high value negative absolute pressure that theoretically can be achieved by increasing fluid's throat velocity.
It is nonsensical since absolute pressures cannot be negative.
CS
Absolute limit of velocity in any throat is going to be sonic velocity. There's your limit right there.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
