Vector Addition: V1, V2, and V3
  • Thread starter Thread starter Eleet
    Vectors
The discussion revolves around the addition of velocity vectors, specifically V1 and V2, where V1 has a known magnitude and direction, while V2's direction is unspecified. The original poster expresses confusion regarding vector addition due to the lack of direction for V2, which complicates the calculation of the resultant vector V3.
  • Exploratory, Assumption checking
  • Participants discuss the necessity of having both magnitude and direction for vector addition. There are attempts to clarify how to express vectors in component form and the implications of missing directional information. Questions arise regarding the true/false statements related to the magnitude of V3.
Some participants have provided guidance on how to approach the true/false questions without needing to add the vectors directly. There is acknowledgment of the confusion caused by the incomplete problem statement, and some participants have expressed understanding after receiving explanations.
The original poster notes that examples in their textbook included directions with vectors, highlighting a potential gap in the problem presented in class. There is a mention of specific true/false questions related to the magnitudes of V3 that are being analyzed.
Eleet
The velocity vector V1 has a magnitude of 3.0 m/s and is directed along the +x-axis. The velocity vector V2 has a magnitude of 2.0 m/s. The sum of the two is V3, so that V3 = V1+V2
I was never shown how to add vectors and this question came up in class discussion and I was clueless.
hmm what college is this you attend?
jk
nice name except one would excpet it in 1337
form
do u still need help with vectors?
Yes well Eleet is the name of my clan on RS3:BA and our tag is 1337.
and Yes I still need help!
If the direction of V2 is not given, then you can't add the vectors. You need both a magnitude and direction for each.
If you have a magnitude and direction for each, just express each vector in terms of its components. For example, your vector V1 points along the positive x-axis and is 3 units long, so its components are:
(3, 0)
Read this as: "three units in the positive x-direction and zero units in the positive y-direction."
If you have some other vector which points along the 45 degree line (measured increasing counter-clockwise from the positive x-axis) and is five units long, its components are
[tex](5 \cdot \cos 45^o, 5 \cdot \sin 45^o)[/tex]
as can be seen from simple trigonometry. To add two vectors with components (a, b) and (c, d), just add their components:
(a, b) + (c, d) = (a+c, b+d).
- Warren
That is what I thought but the question does not give the direction of V2 which really confused me.
Examples in the book gave directions w/the vectors.
It also asked these True/False questions along with it:
(T/F) The magnitude of V3 can be 2.0 m/s
(T/F) The magnitude of V3 can be 0.0
(T/F) The x-component of V3 can be 2.0 m/s
(T/F) The magnitude of V3 can be 6.0 m/s
(T/F) The magnitude of V3 can be 5.0 m/s
(T/F) The magnitude of V3 can be -4.0 m/s
Aha. You don't actually have to add the vectors to answer these true/false questions. Some of the choices are impossible, no matter what direction V2 points. Next time, please post the complete question at once so we'll be better able to help you.
For example, the fourth choice "The magnitude of V3 can be 6.0 m/s," is impossible, because you only have a 3 unit vector and a 2 unit vector. If they point in the same direction, the best case, their magnitudes will add directly to 5 units. If they point in different directions, their sum will have a magnitude smaller than 5 units. If they point in opposite directions, their sum will only be one unit in length. There's no way to add a 3 unit and a 2 unit vector and get a 6 unit vector.
The other wrong choices can be eliminated in the same way by the process of elimination. Let us know if you can't eliminate the others.
- Warren
Sorry about not posting the rest of the problem.
But what you told me helped because I got them right after you explained it.
Thankyou For teaching me something I did not know before.
-Shaun
"If you have some other vector which points along the 45 degree line (measured increasing counter-clockwise from the positive x-axis) and is five units long, its components are
This is often also just written as
[tex][\sqrt{\frac{25} {2}},\sqrt{\frac{25} {2}}][/tex]
Of course, Extravagent, you can evaluate the sin and cos of 45 degrees easily. I chose to express it the way I did to make it clear how it was constructed.
- Warren
I have nothing against that. I was just commenting how it is usually written in books. Your way is a good middle step for if the question asks to write a vector from the info: a vector of length 5 units, 45 degs above the + x-axis... While the way I showed it is often a way a vector is presented.
  • · Replies 23 ·
