mheslep
- 719
Thanksapeiron said:I'm inclined to think Cera is at least as reliable as the Economist. But anyway, shouldn't you really be citing their most recent revised version of this graph?
https://www.cera.com/aspx/cda/client/report/reportImageDisplay.aspx?KID=5&CID=10720&IID=21246
Or the full report download...
https://www.cera.com/aspx/cda/filedisplay/publicfiledisplay.ashx?KID=5&CID=10720&PK=38356
Why are you sorry?Your earlier Cera graph shows plenty of growth in conventional oil production yet. The latest one looks to, err, have peaked, sorry to say.
So?Average across all the spurious bumps of their undulating plateau and the line looks pretty flat at 85 mbd to me.
Unconventional oil still does roar away. But not nearly to the same extent as in the earlier graph.
Things overall look flat from 2020 at around 110 mbd. Then compare this current prediction to the one you cite which says supply will soar in a straight line to 135 mbd by 2035, only then peaking and flattening out.
About resources? If you read the report you'd know that, no, they have not. The changes in production are due to changes in other factors, primarily demand. In neither the older or the newer report to they show any calamitous decline in production. As I said above about the earlier CERA production estimate, "if the demand is there and I don't think it will be." As CERA says in the recent report:So Cera may be reliable. It also seems to have changed its tune drastically in the space of a few years.
CERA said:Supply evolution through 2030 is not a question of resource availability.
CERA said:there should be more than an adequate inventory of physical resources available to increase supply to meet anticipated levels of demand in this time frame. Post-2030 supply may well struggle to meet demand, but an undulating plateau rather than a dramatic peak will likely unfold. Moreover, if the “peak demand” now evident in the OECD countries is a precursor of later developments in the emerging markets, world demand itself could eventually move on to a different course.*
CERA said:But much will happen before then that will affect demand—from changes in the automobile engine and the electric battery to changes in demographics and values. That is why the concept of “peak demand” is so important. Ironically, it may come to be viewed in retrospect as the main driver of peak supply. In that case what happens aboveground will have set the tempo for what happens belowground.
