How to find which z-value to cut at to get the appropriate volume of a sphere
To determine the z-coordinate for cutting a unit sphere to achieve a specific volume, one must use the formula for the volume of a sphere, which is (4/3)πr³. For a unit sphere, the total volume is (4/3)π. To find the z-coordinate that results in cutting off 1/4 of this volume, the volume of the cut section needs to be calculated as (1/4)(4/3)π. The discussion highlights the need for understanding integrals to solve this problem, as integrating the volume of the sphere from the top down to the desired z-coordinate will yield the necessary cut location. A foundational knowledge of calculus, particularly integrals, is essential for solving this type of volume problem.
Pixel08
Hi PF!
I've been trying to find out how one could find which z-coordinates to 'cut' at to get a specific volume of the sphere cut off.
i.e. I have a unit sphere, therefore the total volume is (4/3)*pi*r^3, where r = 1. Now I want to get 1/4 of that volume cut off. So, (1/4)*(4/3)*pi*r^3.
But the problem is, how do I find out where I made that single cut? (The cut has to be horizontal).
Mathematics news on Phys.org
What is your mathematics background?
Hi DivisionByZro! I'm a first year student, just started post-secondary. Not much of a mathematics background - took a differential calculus course last term.
What do you know about integrals?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
