Force experienced by a current-carrying conductor placed in a magnetic field
A current-carrying conductor in a magnetic field experiences the Lorentz force, described by the formula F = Bil. This force is indeed perpendicular to both the magnetic field and the direction of the current. For the formula F = Bil to apply, the current must be perpendicular to the magnetic field. The general expression for the force is F = I l x B, which reinforces this relationship. Understanding these orientations is crucial for correctly applying the formula in physics problems.
richieec
I'm a little bit confused about this...i know that when a current-carrying conductor is placed in a magnetic field, it experiences a force called Lorentz force, this is the formula:
F = Bil
but the thing i can't understand is whether this FORCE is perpendicular to the magnetic field or the magnetic field is perpendicular to the CURRENT?
by the right hand rule, i can see easily that the magnetic field is perpendicular to the force, but in some books and examples it says that the current must be perpendicular to the magnetic field for applies this formula.
welcome to pf!
hi richieec! welcome to pf! :smile:
richieec said:
F = Bil
… in some books and examples it says that the current must be perpendicular to the magnetic field for applies this formula.
for this formula, yes
the general formula is F = I l x B
so this formula, F = BIl, only works if the current direction (l) is perpendicular to the magnetic field
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
