Can Light Travel Faster Than c in Diamagnetic Materials?
The speed of light in a vacuum is defined as 1 / sqrt(mu_0 e_0), while in matter, it is modified by relative permittivity and permeability, resulting in a speed of c / sqrt(k_m k_e). In diamagnetic materials, k_m is less than 1, which raises questions about light traveling faster than 3 * 10^8 m/s, but this assumption misinterprets the role of C, which remains constant. The discussion clarifies that the speed of light in matter reflects phase velocity, not group velocity, with the latter always being less than the speed of light in a vacuum. Furthermore, while some materials exhibit a phase velocity exceeding the speed of light, the group velocity, which is relevant for energy and information transfer, is consistently lower. Understanding these distinctions is crucial in the study of light propagation in different materials.
conquerer7
The speed of light in vacuum is 1 / sqrt(mu_0 e_0). In matter, this is modified using relative permittivity and permeability, so the speed of light in matter is c / sqrt(k_m k_e).
In diamagnetic materials, isn't k_m < 1? Then we'd have light going faster than 3 * 10^8 m/s in, say, nitrogen gas, which is diamagnetic. What's wrong?
You're mostly correct, except for the assumption that C would be the variable that changes. C will stay constant, and relative permittivity will go up accordingly.
This is the phase velocity, not the group velocity. And don't forget the k_e-part, which is usually dominant in matter.
There are materials with a phase velocity larger than the speed of light in vacuum and even materials with negative phase velocity. However, the group velocity (the thing which can carry energy and information, neglecting losses here) is always smaller than that.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
13K
9K
