What Defines a System in Signals and Systems?
  • Thread starter Thread starter amaresh92
    System
A system in signals and systems is defined as a process that transforms an input signal into an output signal, represented through mathematical equations or block diagrams. Systems can be categorized as analog or digital, operating in time or frequency domains, and typically consist of components like adders, scalers, and integrators or delays. Inputs can be provided in various forms, including electrical signals or digital codes, and the concept of delayed input refers to signals that are processed after a time lag, impacting the system's output. Understanding these elements is crucial for analyzing system performance and behavior. This foundational knowledge is essential for studying linear system theory in the context of signals and systems.
amaresh92
how do we represent a system and what does it mean?how do we give inputs to it and meaning of delayed input?
advanced thanks.
advanced thanks.
What kind of system? Analog, digital, time domain, frequency domain, etc.? Can you show us what you have been reading so far on the subject, and ask some more specific questions please?
its is all about both analog and digital system in time domain.they gives the inputs in terms of phase shift of given signal i.e x(n-1) for digital and d/dt(x(t)).what these input represents and how?
advanced thanks.
amaresh92 said:
its is all about both analog and digital system in time domain. they gives the inputs in terms of phase shift of given signal i.e x(n-1) for digital and d/dt(x(t)).what these input represents and how?
this is about Linear System Theory (what they now call Signals and Systems). in either continuous-time (often called "analog") or discrete-time (often called "digital") systems, you have three fundamental blocks:
1. adder (or subtracter), sometimes called a "summer". it adds two or more signals together.
2. scaler (sometimes called "gain"). it multiplies a signal by a constant or coefficient.
and
3. some form that can discriminate between signals with respect to frequency.
3a) in analog systems, usually that device is represented as an integrator and has Laplace transform of 1/s
3b) in digital (DSP) systems, that device is represented as a unit delay and has Z transform of 1/z
you assemble these adders, scaler, and integrators or delays using one of several forms. the most common forms are the Direct Form I (DF1) or Direct Form II (DF2), but you'll see other forms. from those forms and from knowledge of the coefficients, you get a transfer function that fully describes the input/output relationship in a linear, time-invariant system.
I can provide a response to your question about systems in signals and systems. A system is a concept in engineering and mathematics that represents a process or mechanism that transforms an input signal into an output signal. In other words, a system is a way to model how a signal is modified or processed.
There are various ways to represent a system, but one common way is through a block diagram. This is a graphical representation that shows the input signal, the system, and the output signal. The system itself can be represented as a mathematical equation, a set of rules, or a physical device.
To give inputs to a system, we can use various methods such as sending an electrical signal, providing a digital code, or using a physical input device like a microphone or sensor. The meaning of a delayed input refers to a signal that is delayed in time before it is fed into the system. This can happen due to various reasons such as signal processing delays, communication delays, or physical limitations of the system. The delayed input can affect the output of the system and can be taken into consideration when analyzing the system's performance.
In summary, a system in signals and systems is a way to mathematically or physically represent a process that transforms an input signal into an output signal. Inputs can be given to a system in various forms, and a delayed input refers to a signal that is delayed in time before being processed by the system. I hope this explanation helps. Advanced thanks for your interest in understanding systems in signals and systems.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
