Snicker
- 47
- 1
Ok, some background:
In the static case, the force on a charge is the multiplication of the charge into the electric field {\bf{E}}, defined by Gauss' law, the force on a moving charge with velocity {\bf{v}} is given by the multiplication of the charge (which is Lorentz-invariant) into the "Lorentz transformed" electric field {\bf{E}}', which is given by
Whereas {\bf{B}} denotes the so-called "magnetic field," and that Maxwell's equations apply.
_____________________________________________________________
That is, electromagnetism may be viewed as the application of special relativity to electrostatics whilst postulating that electric charge is Lorentz-invariant. Cool, right?
Well, there's this property of Maxwell's equations that I think is too under-appreciated: It is linear in the electric and magnetic fields. The linearity is pretty neat because it implies the principle of superposition for both electric and magnetic fields, which, in turn allows for Lorentz forces to be linearly combined.
So I was thinking: Particularly which features of special relativity imply the preservation of linearity? I think it might be because space-time is an affine space, which is basically linear (an affine space is a vector space that is also invariant under the group of translations). Can a simple, pretty argument explain this connection, if any?
I mean, I'm pretty sure it works. It works for Newtonian gravity (Galilean space-time is also affine and Galilean transformations are identity mappings, which are trivially linear, when applied to a Newtonian gravitational field.)
{\bf{E}}' = {\bf{E}} + \frac{1}{c}{\bf{v}} \wedge {\bf{B}}.
