Quantum physics vs classical physics
Dammes
what i want to know is why classical physics does not work on quantum level particles?
what are the consequences of using classical physics on quantum level particles?
You get the wrong answers, for one. The reason quantum physics was developed was to properly describe the behavior of fundamental particles because the classical ideas failed. For example, the classical electron should fall into the nucleus and emit light as it does. That doesn't happen. They tried to fix the theory but nothing worked. So QM replaced it almost immediately (within a few years) upon its discovery.
There are problems with classical physics applied to quantum objects; you can't explain
- the double-slit experiment using classical mechanics of point particles
- the photoelectric effect using classical electromagnetism
- the blackbody radiation using classical electromagnetism
- the stability of atoms using classical mechanics + electromagnetism
- the spectrum of more complex atoms (the Bohr model only works for hydrogen-like atoms)
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
