Does The Range Equation Work for Complementary Angles?
  • Thread starter Thread starter slr20042003
    Angles Range Work
The range equation indeed provides two solutions for complementary angles, except in the case of maximum range, which is uniquely 45°. When solving for an angle given a specific range, both θ and 90°-θ are valid solutions, unless dealing with an inclined plane. In scenarios involving elevation changes, the solutions adjust to account for the incline angle. While both solutions exist mathematically, practical considerations may favor one angle over the other due to factors like drag and ease of execution. Understanding these principles helps illustrate the real-world applications of physics concepts.
slr20042003
I am a physics teacher and am wondering something about the range equation. Wouldn't that equation work for complementary angles each time? The author of our book has us solving for one angle but shouldn't you solve for two?
If given range, you are solving for angle, yes. You should get two solutions or none. The only exception is maximum range, which has precisely one solution, which is 45°.
In general, if θ is a solution to a range equation at given range, then so is 90°-θ.
Unless, of course, it is an inclined plane. If the plane is at angle α above horizontal in the downrange direction, the solutions will be θ and π/2-θ+α.
I never realized that range with elevation change formula can have such an elegant form when change of elevation is expressed as an incline angle. Good to know.
In real setups, the steeper solution is often impractical, as it gives more drag (and might be more difficult to achieve).
Depends on what you are doing with it. There is a demo I used to show to undergrads in the physics lab. Ask one student to set up a plastic cup 4-6 meters from a spring-loaded cannon (max range ~7m), measure the distance to the cannon, compute angle, shoot a ball bearing into the cup. In that case, you want to go with steeper angle, because it gives you a bigger cross-section to hit and is less likely to knock the cup over. Really drives the point across that simple physics that they learn can actually be used to predict something practical with such precision.
Point is, there are two solutions. Whether one is more practical than the other is a separate issue that has nothing to do with problem itself.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
