Calculating the Maximum Height of a Helium Balloon
  • Thread starter Thread starter heyhey1233
    Balloon Rise
The discussion focuses on calculating the maximum height a helium balloon can rise, considering its mass, volume, and the mass density of the attached rope. Participants clarify that the balloon's volume is not constant as it ascends, which affects buoyancy. The balloon will stop rising when the density of helium inside equals the density of the surrounding air, which decreases with height. The calculations involve using the barometric formula for air density and the ideal gas law for helium to determine buoyancy forces. Final equilibrium occurs when the sum of forces acting on the balloon is zero, factoring in the weight of the rope and the changing conditions as the balloon rises.
heyhey1233
The Helium balloon of total mass=0.200kg and volume 1.00M^3 is attached a a rope with mass density of 1.00g/m. How high will the balloon rise?
I know that air density is 1.204kg/m^3 and that the balloon will stop rising after the density on the inside equals the density on the outside.
I tried calculated that the density of Helium inside the balloon would be .1797g/L, but I am unsure how to calculate when it would reach a height of 1.204kg/m^3?
Not exactly, because the rope pulls the balloon downwards. Does your balloon change volume when rising (normal case), or is the volume supposed to be constant?
The volume is not constant.
heyhey1233 said:
The volume is constant.
Thanks for clarifying that the rope pulls it down!
would be interesting to see what your balloon is made of that the volume remains constant as it rises ;)
Dave
If the volume of the balloon and the density of air did not change with height, one could hang up 1004 g of weight to the balloon -> then 1004 g + 200 g will balance the buoyant force on 1 m^3 large balloon. This means the rope could be 1 km long (1004 m).
However, the density of air and the volume of the balloon will change with height, so the actual height of the balloon may be slightly different than the above crude estimate.
The balloon will expand, which could increase the buoyancy, but the density of air will decrease, which has the opposite effect. If you want to go into that, here is some help:
For density of air, one can use the (as always, approximate) barometric formula
<br /> \rho(h) = \rho_0 e^{-\frac{M_a gh}{RT}}.<br />
where M_a = 28 g/mol is approx. the molar mass of the air (mostly nitrogen) and R = 8.3 J/mol is the gas constant.
The volume of the balloon V can be estimated from the equation of state for helium gas
<br /> PV = m_{\mathrm He}/M_{\mathrm He} R T<br />
where M_{\mathrm He} = 4 g/mol. The pressure P inside the balloon can be approximated by the atmospheric pressure at height h:
<br /> P\approx p_a(h) = p_0 e^{-\frac{M_agh}{RT}}.<br />
With this, you can find out the buoyancy force
<br /> F_B(h) = \rho(h) V(h) g<br />
You have to find also how the force due to rope depend on the height (linear in h); the force of weight is constant = mg.
The balloon will be in final equilibrium when the sum of forces is zero.
Mylar? Plenty of Mylar balloons, and they hold volume pretty well.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
