Amount of Propane Required to Melt 1L Aluminum
  • Thread starter Thread starter Voltux
    Aluminum Propane
To melt 1 liter of aluminum, approximately 2,647,866.23 joules of energy is required, factoring in both the heating and phase change from solid to liquid. Using propane, which has an energy density of about 24,817,687 joules per liter, theoretically allows for the melting of around 9.37 liters of aluminum per liter of propane. However, real-world efficiency is significantly lower, typically around 20-25%, suggesting that only about 3 liters of aluminum could realistically be melted with 1 liter of propane. The discussion emphasizes the importance of using significant figures and understanding the practical limitations of energy transfer in melting processes. Further study in physics and chemistry is encouraged for deeper comprehension of these concepts.
Voltux
I started off yesterday learning about specific heats, and measuring my ice cubes to figure out the correct number to cool my tea to a proper drinking temperature.
Now today I was curious how much propane would be required to melt 1L of Aluminum since I'm also interested in casting Aluminum. I was hoping that someone could check my work, and then tell me how I can get more "Real world" results, or if this would even be practical at all for my level of math/physics/chem understanding.
Also, if you have any concepts you think I should learn next I would appreciate any suggestions. I have some Physics, and Chemistry books that I am reading for furthering my education.
Aluminum
Latent Heat of Fusion: 398 J/g
Specific Heat: 0.91 J/g°C
Density: 2.70 g/cm^3
Melting Point: 660.32°C
Ambient Temperature: 20°C
Mass of 1 Liter Aluminum (Mass = Density * Volume) (1mL = 1cm^3)
2.70g/cm^3 * 1000mL = 2700g
Required Energy for +640.32°C (Mass * Specific Heat * Temperature Difference)
2700 * 0.91 * (660.32-20)
2700 * 0.91 * 640.32
2457 * 640.32 = 1,573,266.24
1,573,266.24 J Required to Heat 20°C Aluminum to 660.32°C
Required Energy to Change Solid -> Liquid (Mass * Latent Heat of Fusion)
2700 * 398 = 1,074,600 J
Total Energy to Heat, and Melt Aluminum (Raise Temp + State Change)
1,573,266.23 + 1,074,600 = 2,647,866.23 J
2,647,866.23 J
735.5184 Wh (Joules/3600)
2509.6929443 BTU (Joules/1055.05585262)
Propane
Molar Mass: 44.1g/mol
Energy Density: 2220kJ/mol
Liquid Density at 25°C: 0.493g/cm^3
Mass Per Liter: 493g/Liter
Moles Per Liter (Mass Per Liter/Molar Mass)
493/44.1 = 11.17913832mols
Energy Density per Liter (Mol * Energy Density)
11.17913832 * 2,220,000 = 24817687.0704J
Amount of Aluminum Melted per Liter of Propane (Energy per Liter Propane/Energy to Melt Aluminum)
24817687.0704/2,647,866.23 = 9.3727118044L Melted per Liter of Propane
The first thing you could do to get more "real world" results is to use significant figures. 24817687.0704? Good heavens!
Well, in real setups, you don't get 100% efficiency. You will heat a lot of air and other parts of your experiment as well. The efficiency really depends on the setup.
Working with units everywhere and with less [strike]in[/strike]significant figures would be useful.
9.372L of aluminum melted using just 1L of propane? Holy moly... Doing it for real will likely result in maybe 20-25% efficiency; you'd be lucky to be able to melt 3L with that much propane for real.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
