Boundary of an open set in R2 is a limit point?
dumbQuestion
I have kind of a simple point set topology question. If I am in ℝ2 and I have a connected open set, call it O, then is it true that all points on the boundary ∂O are limit points of O? I guess I'm stuck envisioning as O as, at least homeomorphic, to an open disk of radius epsilon. So it seems obvious that any points on the boundary would be limit points. But is that true in general?
Let U\subseteq \mathbb{R}^{n} be connected and open and non empty. p\in \partial U if and only if every neighborhood of p contains both a point in U (and in \mathbb{R}^{n}\setminus U but we don't care about that here). Let p\in \partial U and assume there exists a neighborhood V of p in \mathbb{R}^{n} such that V\cap U = \left \{ p \right \} (we know of course that U\supset \left \{ p \right \}). This implies \left \{ p \right \} is a non - empty proper clopen subset of U which is a contradiction because U is connected. Thus, p is a limit point of U.
thank you very much!
Should work for any Hausdorff connected space and not just euclidean space as far as I can see. Was there a particular reason for this question or did it just pop into your head for fun or something= D? Cheers!
Unfortunately this does not work since open sets will not contain their boundary points. Luckily that observation gives us a way to fix the proof. All we now have to note is that the boundary point condition implies that every nbhd of p non-trivially intersects U - {p} = U.
Totally missed that detail haha. Maybe the OP didn't mean to say open but another class of subsets because he was trying to use connectedness explicitly. Anyways, I got to go to class now so cheers!
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
