Squaring of vectors in absolute value
The discussion clarifies that |\vec{a}+\vec{b}|^{2} is equal to (\vec{a}+\vec{b})^{2} when the right expression denotes the dot product. It emphasizes that vector multiplication is not generally defined outside of the dot or cross product. The magnitude √(a^{2}+b^{2}) represents the length of the resultant vector when \vec{a} and \vec{b} are orthogonal. This relationship highlights the importance of vector orientation in determining magnitude. Understanding these concepts is crucial for accurate vector analysis.
M. next
Is |\vec{a}+\vec{b}|^{2} equal to the same thing as (\vec{a}+\vec{b})^{2}? And when is it equal to √(a^{2}+b^{2})?
Thanks.
Mathematics news on Phys.org
They're the same, assuming the implied multiplication in the expression on the right is the dot product. Otherwise, multiplication of one vector by another is not defined (with the exception of the cross product).
Tip: You don't need so many tex or itex tags. Your squared vector sum can be written like this:
[itex[/color]](\vec{a} +\vec{b})^2 [/itex]
Or instead of the itex tags, you can use ## delimiters at the front and back.
Thank you for the reply and the tip. But about the √(a^2+b^2)?? My second part of the question?
That is merely the magnitude of both vectors. Assuming that's what you mean? You were a little unclear on the second part. Think of magnitude as the size or length of those two vectors.
\sqrt{a^2+b^2} is the magnitude of \vec{a}±\vec{b},where \vec{a} and \vec{b} are orthogonal (perpendicular) vectors.
Okay. Thank you, yes, it is exactly what I meant.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
