Find the Best Glue for Aluminium Foil - Buy in Bulk!
  • Thread starter Thread starter Notinuse
    Aluminium
Recommendations for gluing aluminum foil focus on finding a non-reactive adhesive available in larger quantities, such as wood glue or wallpaper paste. Aluminum's reactivity is highlighted, particularly its interaction with the AlOH film that forms on its surface, which can be disrupted. This disruption can lead to unwanted reactions, especially in applications involving food safety. The discussion also touches on the challenges of soldering aluminum due to its inert surface when intact. Overall, the need for a suitable adhesive that maintains the integrity of aluminum's surface is emphasized.
Notinuse
I need a recommendations on a glue to stick aluminium foil.
Due to the size I need a product that can be brought in larger quantities rather than in small tubes; like a tub of wood glue or wallpaper paste.
I'm asking because aluminium is reactive and I need something that will stick, but not react.
Reactive with what? You know, they wrap food with aluminum foil.
Aluminum is very reactive, if you disrupt the AlOH film that forms on the surface (of the order of only one molecule thick) when it is in contact with air.
That's why mercury-in-glass thermometers are banned from aluminum-framed aircraft.
https://www.youtube.com/watch?v=zbUPjHHml1E
On the other hand, AlOH is very inert, which is why Al is hard to solder, for example - but if the surface film has broken and can't re-form properly, it is virtually impossible to stop the reaction.
I was once stirring molten Al with a Stainless steel rod...The stainless "melted" into the Al. Al is very reactive, of course molten Al is more so then solid due to the thermal energy present.
Isn't this as much of a demonstration of the re activity of Hg as well as Al? I once was playing with some Hg, great fun!, and watch regular tin/lead solder simply vanish into the Hg.
Since the foil is pretty air tight 'drying adhesives' probably aren't going to work.
